JUST BOUGHT ME a 1983 280zxt 2+2 5speed !
Old Jun 22, 2006 | 07:04 PM
nismo619's Avatar
hey u guys i had a friend out in portales new mexico 88130 who just sold me his personal car he was fixing up a 1983 9th month of 82 digital dash 5 speed 280zx turbo 2+2 right on huh ! i bought it for 250 dollars ! im in need of a ECU thou as the old one was RIPED. i have a ecu from a 1981 280zx turbo auto tranny will that one work ? any help from u guys will help me out !
1 ECU
2 Gas Cap.
3 Ignition switch with key.
4. 1 iron cross 14 inch wheel. i have 3 of them only.
that list is what i currently need i will be posting pictures of this car tomorow
Old Jun 22, 2006 | 07:06 PM
jfairladyz's Avatar
no, the 81 turbo ECU is not compatible with the 82/83 turbo motors. But the 82 and 83 are interchangeable.
Wahoo! Add another to the list!
Old Jun 22, 2006 | 07:08 PM
jfairladyz's Avatar
and i have a good ignition switch but I'll have to see if I can find the key. It's out in my shed somewhere. If I find the key I'll let you know. The switch is perfect and practically brand new.
Old Jun 22, 2006 | 08:04 PM
nismo619's Avatar
right on jfairladyz... how much would u want with te switch and the key... ? i cant used the flat head screw driver any longer i cringe at looking at it.. the guy lost the key and used a flat head screwdriver to start the car..this is my new prodject car.. the inside parts are all there ! looks pretty good to me.. i got the title in hand..
Old Jun 22, 2006 | 09:02 PM
skittle's Avatar
Taste My Rainbow
lucky i would kill for a turboz
Old Jun 22, 2006 | 09:37 PM
Man... you're right by Cali & AZ... and IN Vegas... there's tons of 280zxt's down there!
Old Jun 22, 2006 | 09:41 PM
bradyg's Avatar
you would kill for one hell i didnt kill i bought one for 50 bucks and it runs and drives
Old Jun 23, 2006 | 07:07 AM
nismo619's Avatar
the one i bought doesnt run right now but i bet every one i will have it up and running in a few months. no problems. ! come on guys i still need to find a used 83 digital dash ECU.. thats the main thing right now...
Old Jun 23, 2006 | 07:56 AM
Having a digital dash doesn't make a difference.
Old Jun 23, 2006 | 07:00 PM
jfairladyz's Avatar
the only real difference on the digital cars is the gauges wiring harness. My car was a digital dash, but I converted to analog. All's I had to swap was the dash harness. Of course I'm regretting this all now that I'm sitting here with a bunch of broken gauges thanks to a certain 3 year old
nismo619, I'll pm you about the ignition switch as soon as I find the key. I'm going to clean out my shed tomorrow and the key is in there somewhere (I hope).
Old Jun 23, 2006 | 07:38 PM
skittle's Avatar
Taste My Rainbow
unless you are looking some where i'm not , I can't seem to find them unless they are asking 1500 plus...
Old Jun 24, 2006 | 12:20 AM
nismo619's Avatar
Up date i got home from work today at 3:30 pm first thing i did was get into my work clothes and started work ASAP on the new Z car.. well hears the list of what i did so far, Bleed the entire brake system inspected the brake calipers and pads, gressed up the caliper pins, e brake cable was stuck so i took of the two wires to the rear calipers for now until i unfreeze the line, bleed the front brakes and did the same work to the front as i did to the back i put on my spare 280zx turbo rear light panel i have .. took off the one it came with stock 280zx no turbo light emblem on it wires it up to work. changed out all the black fuses in the main fuse box by the right head light there was 2 missing ? lol i put in my spare 280zxt fuel rail i had siting ... why i did this is becuase when i inspected the fuel injectors two of them were green top fuel injectors.. OUCH,,, ... so i changed out hte fuel rail with some good used real turbo fuel injectors its 1:20 am i just got inside from taking off the ignition switch thank god it has had a new one before it just had 2 screws in it.. i do belive im ready for a new igniton switch. any tips ? any helpfull hintz ?
oh yea i also droped the fuel tank cleaned it out and reinstalled it tonight too... so 3:30
3:30 to 5:30 did the brake system
5:45 to 7:15 did the fuel rail , injectors etc
7:35 to 1:15am worked on the fuses ,checked out the wireing ,drop and clean and reintstall the fuel tank , took off the ignition switch , also hookd up the rear 280zx turbo panel... so a total of 9 hours plus i worked on this car today.. i cant wait until i can drive it.. tomorow i will be taking pictures etc..
Old Jun 24, 2006 | 08:00 PM
nismo619's Avatar
New up date i have changed out the AFM.. The distributor .. the spark plugs ... fixed the fuel tank ...and fuel pump im getting gas to the cylendar but no spark i have checked the coil its good ive cheked the distributor.. it trys but nothing... any hints? maybe a fuse ? i pulled off all the new spark plugs there soked badly with gas..
Old Jun 24, 2006 | 08:50 PM
EatmyDust's Avatar
Ignition module maybe!
Old Jun 24, 2006 | 10:22 PM
jfairladyz's Avatar
The reason the plugs are covered in fuel is because the ignition isn't firing so the fuel isn't burning. Nothing to be alarmed about (well other then the fact that there is no spark )
I found the ignition switch Nismo...Still looking for the key. The shed is almost all cleaned out except for my workbench (which is where I suspect the key is). So I'll let you know for sure by tomorrow.
Old Jun 24, 2006 | 10:46 PM
nismo619's Avatar
alright yall i am inside now i worked from 3:30 until 11:40 pm new mexico time so far thats over 15 hours total in 2 days... good news i fixed the wireing problem.. got both windows to roll up yaaaa... some one criss crossed the left door wires.. still two wires i dont know were they go ... there two coming out of the window switch.. the other wires are correct but two left with no leads? anyways im trying to find out the " RELAYS behind the GLOVE BOX " 2 blue relays and one green one what are they for again ? sorry i forgot and im having problems finding these items in my HAYNES manual..
p.s. the blue relays have no stickers..
1 the green relay sticker is missing =-(
I really want to see this car running ASAP
Old Jun 24, 2006 | 10:49 PM
jfairladyz's Avatar
behind the glove box you have the accessory relay, the ignition relay, and the fuel pump relay. The green one is the fuel pump relay.
Old Jun 24, 2006 | 10:53 PM
nismo619's Avatar
right on jfairladyz i knew if any one knew u would.. thanks i got a spare fuel pump relay and thank god i had two blue relays left down stairs im gonna tuff up and go out side and make this car start tonight !
Old Jun 24, 2006 | 11:19 PM
nismo619's Avatar
Nope wasnt the relays after all.. so i have finnaly located the problem must be the spark.. if only number one spark plug is fireing why isnt the rest fireing ? any help ?
Old Jun 25, 2006 | 06:56 AM
EatmyDust's Avatar
mabe it the plugs or the cap. hey jayfair what if a certain 3 year old took the key for there little toy car, are you going to take it away? I mean gosh with no car key hows the poor thing going to get around town? Sugesting swap with another key, like your wife's car key, or girlfriend which ever she is lol.
she may be going nowere, but hey the 3 year old can be the d.d.
Old Jun 25, 2006 | 07:04 AM
nismo619's Avatar
i bought all new spark plugs so it must be the cap and rotor?
Old Jun 25, 2006 | 10:05 AM
duowing's Avatar
NisTuner
You said you're positive that you're getting spark to the ignition coil? Also pull off your cap and check your rotor for build up on the contacts.
Old Jun 25, 2006 | 10:06 AM
try cap and rotor 619, and if j cant find his key, i may have a 82 switch with key in good shape, ill find it, im in the same predicament j is in, i gotta find it. i think from experiance, that when storing the iggy switch, one should tape the key into its place so one may loose it. so now i gotta find all the keys to all my switches!!!
Old Jun 25, 2006 | 12:50 PM
EatmyDust's Avatar
How new are the plug wires?
