ZDriver.com
-   -   injectors (https://www.zdriver.com/forums/280zx-performance-technical-79/injectors-9016/)
Skully Apr 16, 2004 10:14 AM
injectors
ok what injectors are same as in a 81 na 280zx? ibroke the lil plastic tip on one of mines....also it fell down the injector hole will that screw me up!?
SHADY280 Apr 16, 2004 06:48 PM
Yeah That Would Go Into The Engine And Poss. Damage Somethin. Injectors Can Be Bought New, Used, Rebuilt, Z's From 79-83na Had Same Injectors And The Pulsars Too.
Skully Apr 16, 2004 09:31 PM
Originally Posted by SHADY280
Yeah That Would Go Into The Engine And Poss. Damage Somethin..
awwww crap what am i gonna do........
rinyt-79 Apr 17, 2004 08:47 AM
I once dropped a washer down an intake port and spent all afternoon fishing that thing out - not fun. Your injector tip is just plastic though. It should mostly burn up during combustion. Even if the thing bounces around a few revs, it's still just plastic. Since you also don't have a turbine wheel to worry about, this is pretty low risk.
Skully Apr 17, 2004 09:44 AM
yeah and its not even the whole tip its just like corner of it
a washer damn ...
AllmyZs Apr 17, 2004 10:05 AM
If you think it is smaller than a 1/4 inch you should be OK. As long as it is only plastic and nothing metal got in there. My friend drop and jet out of his carb down his manifold. It siezed the motor. So if you are sure it is plastic and small then you should be safe to just burn it out. I only worry about it exiting thru the exhaust valve.
Skully Apr 17, 2004 10:42 AM
yes its just a chip of the injector...yeah im woried abou that too..:( oh well thats what ya get for being stupid
Skully Apr 24, 2004 10:35 PM
how do you get the hose of the injector.??
