Injector question.
The injectors on my '80 280zx need tp be replaced.. Would it cause a problem if I replaced them with the turbo injectors? I'm not looking for a performance gain, I just found a really good deal on the turbo injectors.. I'm thinking that the o2 sensor will detect if the car is too rich & lean it out.. Am i right or will the car always run rich?
The O2 sensor will compensate a small amount, but I've heard its not quite enough. It will run rich at lower rpms and midrange. If you modify your engine with a ported intake and really big cam, then at higher rpms where you might normally run lean, you'll be fine. :D
Turbo injectors in a NA engine is not usually wise. |
| All times are GMT -7. The time now is 05:02 AM. |
