ZDriver.com
-   -   Idle High help Plz (https://www.zdriver.com/forums/280zx-performance-technical-79/idle-high-help-plz-32129/)
Lupe Mar 2, 2011 09:00 AM
Idle High help Plz
My car Drives Normal But When I Go To Stop And Push The Cluth The RPM's Stay At 2000rpm For About 5 Seconds Can Anyone help Thanks
NismoPick Mar 2, 2011 09:36 AM
Welcome to ZDriver! :006:
When did this problem start? Did you recently do any work on the car? The more info you give us, the easier it is to help you. :D
-Check the timing
-Check for vacuum leaks
-Check for any disconnected sensors
SHADY280 Mar 2, 2011 12:00 PM
i had that and it was my timing. but its good to check the rest while your there
rogerz Mar 2, 2011 03:28 PM
sticky throttle linkage.
Lupe Mar 12, 2011 03:48 PM
IDK I Got The car Like This I Checked My Timing But It Was Fine Throttle Linkage Is Fine Too But My Car Is Running A Little Rich And Failed Smog....Could This Be Causing This?????
WildmaN Mar 12, 2011 06:11 PM
Check all your sensor connectors, and make sure they are clean, and have good contact. Also if that doesn't help, check your injectors, and make sure they are all working correctly. That should give you a start, good luck man.
Lupe Mar 12, 2011 06:53 PM
Thanks Ima Try Cleaning My Connections They Do Look A little Dirty....
WildmaN Mar 12, 2011 07:49 PM
Yeah if they have a greenish color on the contacts. Just use some Wd-40 and a toothbrush. And let it air dry. Makes a huge difference. And you are welcome. :)
SHADY280 Mar 13, 2011 02:59 PM
you can also clean the green off with baking soda. make a paste and it will fizz. the wash it off with water when the fizzing stops. no bush required. it will also take corrosion off where the brush cannot reach, even up the wire sheathing. running rich can be the afm, too high fuel pressure, bad plugs, temp sensor, cold start valve stuck on and o2 sensor
FricFrac Mar 14, 2011 03:58 PM
The linkage may be OK but the actual butter fly valve inside the throttle body might be sticky as well.
Lupe Mar 23, 2011 01:40 PM
Ok And If It Is The Cold Start Valve Could I Just Eliminate It Or Does The Car Really Need IT????
NismoPick Mar 23, 2011 09:10 PM
Before you go removing things you shouldn't... did you heed the previously stated advice of checking for vacuum leaks and loose/corroded sensor connections?
Lupe Apr 4, 2011 08:41 PM
I Cleaned My Connectors Checked For Leaks No Leaks and I Checked My FPR And It Was Leaking Through The Diaphram So I Changed Now It Rinning Better But Still Hanging And Running Rich I Also swapped My Afm from My other Z and It Ran The Same
Dassan80z Apr 5, 2011 12:57 PM
Check the injector pig tails. Also the IAC might be sticking.
Also seen this problem being related to a faulty power steering pressure switch or A/C pressure switch. Which bumps the idle up when engaged to keep the motor from bogging down.
Lupe Apr 5, 2011 10:34 PM
I Never Thought about The Power Steering Thing It has been Acting Up On Me Tho I Makes A Tiking Sound Sounds Like A Rod Knock And When I Took The Belt Of It Stopped... Now The Idle Doesn't Hang As Much Now It does It Sometimes And Sometimes It Doesent :/
NismoPick Apr 5, 2011 11:03 PM
um... I'm pretty sure the 280zx doesn't have a "power steering switch".
Dassan80z Apr 6, 2011 11:06 AM
You are right, it does not have a ps switch, but has a/c and oil pressure. Though after thinking about this it seems more like a throttle body problem. Try cleaning it, if that doesn't work I would try adjusting the tps and or iat to see if it makes a difference.
Lupe Apr 6, 2011 12:01 PM
Ill Try Cleaning It Out Anyways I Have Nothing To Lose...
