Holy!@#%
Old Jun 10, 2011 | 10:37 AM
Tsuka89's Avatar
Exclamation Holy!@#%
ok so i was driving down 405 and i hear a pop and then a clank/ping, then about 5 minutes later also on 405 i hear the same thing. I keep driving because im only about 2 miles from my apartment, and then i hear another ping/clank after a speed bump on my way up to my apartment. I park the car check everything out in the engine with the engine on, and nothing seems disconnected or anything. then I walk down to where i heard the clank after the speed bump and find this laying on the ground! no idea if it goes to my car or what but it seemed to be in the right place. where the hell does it go? and how many are on that piece because i have a feeling that more parts than that fell out on the freeway. sounds like it came from the middle of the car somewhere or from the firewall or tranny tunnel
kinda worried
Old Jun 10, 2011 | 10:57 AM
evandubya's Avatar
Primer Grey FTW!
check all your rear suspension parts.
Old Jun 10, 2011 | 11:07 AM
Tsuka89's Avatar
awesome, dont exactly have the parts to do that at my apartment, um safe to drive to a friends house?? any other ideas are appreciated thanks
Old Jun 10, 2011 | 11:17 AM
evandubya's Avatar
Primer Grey FTW!
Crawl under it and look for missing nuts, broken sway bar, something out of place.
Old Jun 10, 2011 | 11:20 AM
Looks like the big washer that goes on the tension rods (front suspension under the bottom radiator cross support).
Might want to check that.
Old Jun 10, 2011 | 11:29 AM
Tsuka89's Avatar
even better, if its the tension rod shim, can I get it anywhere or is this going to be a part thats impossible to find, and since its front i will probably not want to drive on it till its fixed, correct?
Old Jun 10, 2011 | 11:32 AM
Well... you apparently still have one that you recovered. I imagine it's the outer one because you probably wouldn't have made it home if the inner one fell off (meaning the tie rod completely separated from the cross member.
I suggest going out and looking at it right now...
Old Jun 10, 2011 | 11:36 AM
Tsuka89's Avatar
well ok that just put a damper on my weekend,
thanks for the help will update after i look at it
Old Jun 10, 2011 | 03:13 PM
Tsuka89's Avatar
ok so yep sure enough its the tension rod, the bushing is still there but the outer washer and the nut are gone, it would seem like those would need to be torqued down??
anyway assuming hardware store will have the parts, just gonna take the ones off the other side in and get them that way
Old Jun 10, 2011 | 05:02 PM
JSM's Avatar
JSM
It also reminds me of the washers used on the Mustache bar.
Old Jun 10, 2011 | 05:28 PM
Tsuka89's Avatar
anyone know if they are any torque specs on this nut?
Old Jun 10, 2011 | 06:28 PM
JSM's Avatar
JSM
I'm sure it's in the FSM. Just down load it.
http://www.xenonz31.com/s130/reference.html
Old Jun 10, 2011 | 07:32 PM
Tsuka89's Avatar
lol, wow, I have it already, and didnt even think about looking there
Old Jun 12, 2011 | 12:50 AM
Matt K's Avatar
I've broken ZX tension rods using polyurethane bushings...if you need to replace them, use either new rubber bushings, or half poly & half rubber. The poly doesn't give enough & it snapped in only a month!
Old Jun 12, 2011 | 10:45 PM
Tsuka89's Avatar
did you replace the tension rods too when you put in the urethane bushings?
Old Jun 16, 2011 | 02:35 AM
Tsuka89's Avatar
bumping for question; how am I supposed to get a torque wrench in there to torque the tension rod nuts now???
Old Jun 16, 2011 | 11:30 AM
PurePontiacKid's Avatar
i felld offa mai trike
just tighten it down with a wrench
and not give one **** about it
Old Jun 17, 2011 | 07:20 AM
Technically you will need an alignment after removing / replacing a tie rod. Get it snug and take it to an alignment shop. You can't really "torque it to spec" because it has a plastic bushing that will keep "squooshing" together as you tighten...
Old Jun 17, 2011 | 08:03 AM
evandubya's Avatar
Primer Grey FTW!
squoosh (skwsh)
tr.v. squooshed, squoosh·ing, squoosh·es Informal
To squash or squeeze:
funniest word ever!!!!!!!!!!
Old Jun 17, 2011 | 11:34 AM
Yeah... ya know... "squoosh! squoosh!" New word for today's intrawebnet advanced technology.
Old Jun 18, 2011 | 11:25 AM
duckyz's Avatar
A good old "Monkey Twist" should hold it...
Old Jun 18, 2011 | 10:23 PM
Tsuka89's Avatar
500 mile journey coming up; don't really want the damn thing to fall off again, any other ideas, blue 242 loctite?? nylock nut?
Old Jun 19, 2011 | 07:49 AM
Just match the other side (unless the other side is about to fall off too). IIRC, you should see a couple rows of thread sticking out the top of the nut (stock).
BlueKitsune
Jul 2, 2009 03:54 PM
RodMoyes
Apr 20, 2008 10:59 PM
s/cL3.0
Jan 15, 2006 05:52 PM
roneski
Aug 10, 2005 02:37 PM
4rdhater
Aug 30, 2002 09:34 AM
