Hi everyone, I just bought a 81 ZXT. What should I do to improve performance?
Old Apr 8, 2003 | 11:36 PM
lifegrddude's Avatar
Externally Wastegated
Wow, big goals there, but shouldn't be too hard except for the aftermarket exhaust manifold. Only company I know of that you might be able to get one from is Greddy and those suckers are expensive. 1500 bucks or so if I remember correctly, but worth it if you're going all out hp. Allows you to use their Mitsubishi TD series turbos. For the cam you can contact MSA, they have them, not sure what brand it is, the 3spd to 4spd swap is listed on the zcar.com site under articles, the port and polishing bit, I don't know, maybe extrude hone or someone can help you out. The rear end, if you can find a turbo Z31 with an LSD, it's a 3.7 and does a good job. I think a 4.11 would be too tight, but that's just me. Easiest way to 300 hp is to find a t3/t4 turbo, upgrade the injectors to either 370cc SVO Mustang or 420cc Mercedes 450 ones, a bigger pump, 3" exhaust/downpipe, and an i/c with the boost cranked up a bit.
Since you said you're in Southern Cali, check out the Z car show in Orange county on the 27th and you will see about 300 Z cars all with different setups. www.zcarparts.com has more info.
John
Old Apr 10, 2003 | 11:15 AM
If you must overbore, a 3mm overbore is the maximum safe bore.
That'll bring you up to about 2.95 L Not quite a 3.0
Old Apr 22, 2003 | 10:52 AM
veyenyl's Avatar
If you have a ZX turbo and want to make more power you need to get out of the normally aspirated mindset. 4.11 gears are not good for turbo cars. Stock turbo Zs came with 3.54 and NA Zs had 3.90s so you would be going in the wrong direction. The reason you don't want the 4.11 for a turbo car is you won't be able to build full boost before shifting.
To get to 300hp you really don't need to do major headwork. Stick with the stock turbo cam unless you really know what you're doing. Start with a 3" exhaust and downpipe. Then get an efficient intercooler capable of supporting your hp goals and up the boost. You will then have the foundation for any additional upgrades to get you to 300 hp.
dts130
Nov 7, 2011 07:23 PM
CanyonCarver
Jul 27, 2008 07:00 AM
johncdeere
13
Apr 17, 2008 06:19 AM
KurumaZ
FS: 300ZX (90-96)
May 17, 2005 12:11 AM
nzz
Aug 28, 2002 09:43 PM
