hey guys
Old Apr 3, 2011 | 05:55 PM
dirtyZX's Avatar
From: i live in FL but im stationed up in Washington state
hey guys
sooo i made a wish list for my 280zx, im not a veteran to working on cars but i feel like i might get some good power out of what i plan on doing, maybe you guys can help me out, what kind of power do you think i would get with all of these things, i made a list, mostly from MSA but any help would be good. im not looking for like 300 horsepower but just enough to get her running good and strong for miles to come. and another thing, one of my cylinders isnt moving, any ideas??
Kameari Fully Adjustable Performance Cam Pulley, 70-83 Z/ZX
234.95
http://www.thezstore.com/page/TZS/CTGY/PEM11
Performance Cam Kit, 70-83 Z/ZX Non Turbo
799.95
http://www.thezstore.com/page/TZS/PROD/PEM01/10-2000
SALE! MSA 3-2 TBC Coated Header, With Smog Fittings, 81-83 280ZX
299
http://www.thezstore.com/page/TZS/PROD/PEC03/15-6017CH
SALE! MSA Aluminum Driveshaft, 79-83 280ZX Coupe Non Turbo
399.95
http://www.thezstore.com/page/TZS/PROD/PRC02F/22-1036
Oil Cooler Kit
115.98
http://www.thezstore.com/page/TZS/PROD/PCLC03B/17-8051
SALE! PerTronix Coil, Black, 70-83 Z/ZX
35.95
http://www.thezstore.com/page/TZS/PROD/PEIC03/12-4061
Centerforce One Clutch, 75-83 280Z-280ZX Non Turbo Coupe
245.95
http://www.thezstore.com/page/TZS/PROD/PCC01/21-2002
and just for fun
SALE! Carbon Fiber Valve Cover Cap, "POWERED BY DATSUN" Red, 70-83 Z/ZX
184.00
http://www.thezstore.com/page/TZS/PROD/CFP/10-2064R
let me know what you guys think, thanks agian
Old Apr 8, 2011 | 06:51 AM
dirtyZX's Avatar
No One?
Old Apr 8, 2011 | 07:29 AM
i wouldnt bother getting a cam unless you plan on upgrading the ecu. the stock ecu really cant handle changes like that and you wont see a lick of power increase from it. for example my friend and i both had 280zx's. mine was fully bored out and had a decent cam and headers and big exhaust, and headwork. all his had was a p79 decked .080". he could nearly keep up with me. i made it my goal to get an aftermarket ecu after that point. the driveshaft is a waste of money, go for a lightweight flywheel if you really want to spend the money. youll also need the dual friction centerforce then. dont just stick with msa for your items, try the interwebz and do some research itll save you some coin
Old Apr 8, 2011 | 07:36 AM
evandubya's Avatar
Primer Grey FTW!
I'm almost certain that won't get you anywhere close to 300hp. You'll need a 240sx throttle body, bore out your manifold, z31 or megasquirt ecu, high compression engine.
Old Apr 8, 2011 | 09:59 AM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
I would suggest figuring out your misfire before you go and spend 2200 bucks on stuff you don't need...
Old Apr 8, 2011 | 03:59 PM
dirtyZX's Avatar
well i do plan on figuring out why its misfiring, thats the first plan, already have new injectors on the way, i was trying to find a fuel rail online and i really couldnt, any help for a good one?
Old Apr 8, 2011 | 08:21 PM
Click: http://www.freewebs.com/pallnet/index.htm
Old Apr 9, 2011 | 07:01 AM
rossmachining sells blank rails, if you know how to use a tap its uber cheap.
Old Apr 9, 2011 | 09:46 AM
dirtyZX's Avatar
i know about cars very well but i dont know about working on them, like i have in the past but im doing it on my own now as i go along, kinda a hobby to get me outta my daily grind bulls**T. and do you guys have any ideas on why a cylinder wouldnt be firing,
Old Apr 9, 2011 | 11:05 AM
Stuck / clogged injector, worn spark plug / spark plug wire, burnt / bent valve.
Old Apr 9, 2011 | 01:58 PM
dirtyZX's Avatar
well i ran into another problem, it wont start, it started the other day when i jumped it but now it wont, and all i hear is a buzzing sound that comes from the fuse box, when i go to start it my voltage drops to nothing, and then all i hear is ticking and sparking of some sort, cant really tell what it is....heeeeellllllppppp!!!!
Old Apr 9, 2011 | 02:02 PM
A dead battery... or corroded / loose battery terminals.
Old Apr 9, 2011 | 02:04 PM
dirtyZX's Avatar
i checked all that, its all in order new bat and everything
Old Apr 10, 2011 | 12:13 AM
81SacUti280zx's Avatar
possibly check the started...or maybe since you said one of the pistons wont move is the engine siezed? make sure all your grounds are connected and start checking fuses...or links. The fuseable link box next to the battery was the cause of my z not starting some years ago. I had 2 bad "burnt" links.
Old Apr 10, 2011 | 11:02 AM
dirtyZX's Avatar
hmm ima check that out today, thanks for the advice
thxone
Feb 25, 2007 01:55 PM
902+2
South Region
Jul 3, 2006 07:28 PM
roneski
Sep 10, 2005 05:38 PM
ThermalWake
Aug 1, 2005 07:06 PM
Zrolimit
Jun 4, 2005 01:15 AM
