Harmonic help!
Anyone know where the little pin goes when installing the balancer ? I think I know where it goes but it looks like it will fall out :102:
Pin? As in woodruff crank key?
(Post 313619)
Is it shaped like a half moon? |
lol thats it ! I looked in the manual and could'nt find where I need to put that at?
At the front of the crank shaft in it's female slot (inverted half moon).
Keep looking at your diagrams. Ya know how you plug in an electrical cord to your wall? Same idea... put the key in the slot, curve down, flat side up, slide on pulley. |
Ok thank you I will check my book tonite then i will tackle that this weekend
Just an FYI... if you google "woodruff key" or "crank key" and search for images, you will get about 1.2million pics for you to see. :D
Okay the car is at the shop just ordered some new gaskets for the crank should have them by monday from the z store injectors are next after i get this car started
(Post 313634)
Well... ya just kind of plug it in.
Finally the car is running kinda great starts right up now but still need some more stuff !
I need the throttle body and the air box that is connect to it anyone have one for sale or donate ? |
ok now I need to know if there is a MSD ignition coil that will fit my car any ideas?/
Lots...
MSD Blaster II is what I'm running. There are also solid state ones. |
(Post 318367)
Lots...
1 Attachment(s)
Here is a updated pic I got it painted over the weekend pewter sorta like the Buc's color on the jerseys now all I need are wheels
Attachment 17052 |
