Gots a question!
Does anyone know how much the L28 puts out after a 3.1 bore kit from MSA, and/or the stage II cam kit from MSA? I plan on doing both of these but wanted to find some numbers first. :confused: :D :confused: :D
http://www.bbgraphics1.com/73z/index.html This guy has something similar to that setup.
dammmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm :D
So with the bore kit, Cam kit, Python injectors, Rising-rate FPR, Performance tuned ECU, Completely open side pipes, 6-2 headers, and a port and polish P90 head, I should push about 300-350 WHP, does that sound right to everyone else? God I hope so! That is my winter project plans. Oh, Almost forgot... True forced induction Ram-Air! of course with at least a 240sx throttle body.
Somewhere in between there sounds pretty good, with a tuned ECU and, most important of all, you're going to have to bump up your compression ratio a bit. He was making those numbers because he had 10.5:1 compression ratio. You're looking at a high octane fuel to put out those kinds of numbers NA.
Man are those cylinder walls thin! But that is pretty good for that kind of bore!
