fuel relay
Old Jan 11, 2016 | 02:58 PM
skip3535's Avatar
fuel relay
I recently have picked up a 1981 280zx base model. The car had been sitting in a barn for 5 years. After checking all fluids the oil looked new and it didn't have any fuel in it and there was no battery. I put fuel in it and jumped it with some cables and after 4 or 5 cranks it started. I let it run for about 3 min. and when I took the cables off it died. I guess you need a battery for this car to run. The car would not start again after that. I think it was flooding out. I put a battery in it and still was flooding. I decided to take out the #2 fuel relay and the car will start and run without it but if I put it back in the car dies and will not start. It does idle a bit rough but runs. Has anyone seen this before? any help in the right direction is appreciated.
Old Jan 11, 2016 | 07:13 PM
Welcome to ZDriver!
First, make sure you've downloaded the FSM: XenonZcar.com S130 Factory Service manuals
Second, do some tests of the CHTS, and AFM. Also test to see if all 6 injectors are firing. Read the spark plugs, etc etc etc...
Old Jan 12, 2016 | 05:27 AM
skip3535's Avatar
thank Ill check it out
Old Jan 15, 2016 | 03:37 PM
skip3535's Avatar
I tried most of the fuel system tests on the computer. The only thing that failed was the thermotime switch and exhaust gas test. I tried to disconnect the extra fuel injector but still no help.
wrenchwench
Apr 6, 2015 03:27 PM
Creator
May 31, 2004 12:59 PM
littlezippy
Apr 29, 2003 12:31 PM
280ZXtreme
Apr 10, 2001 07:00 AM
280ZXtreme
Mar 24, 2001 02:07 PM
