fuel regulator
Old Oct 13, 2005 | 02:17 PM
efrain's Avatar
fuel regulator
Is a good option to get a performance fuel regulator? Where could I found one?
Old Oct 13, 2005 | 02:20 PM
nope... deffinately a BAD option. the word "performance" in Latin actually means "crappy."
Try ebay... they have a gazillion fpr's... if you have a turbo setup, get a rising rate fpr. If you have an n/a setup... I don't think ya really need one... but hey, why not?
Old Oct 13, 2005 | 02:43 PM
efrain's Avatar
There is no specifications? Can I buy anyone? And hey nismo, the thing is; will I get any bennefit from it? My car is N/A
Old Oct 15, 2005 | 04:22 AM
Heat Rave R's Avatar
Unless you've built up other areas of your engine, an adjustable FPR probably won't do much good.
Old Oct 15, 2005 | 08:27 AM
efrain's Avatar
Well my NA just have headers, cold air intake, msd, ported, 60 mm TB. Will the FPR make any difference?
Old Oct 15, 2005 | 09:14 AM
hey efrain... did you know that you don't have to "attach" that pic everytime... you can just put it in ya signature.
Old Oct 15, 2005 | 11:03 AM
efrain's Avatar
I know I just like to change it from time to time. And it would be very helpfull if you can answer the question.
Old Oct 15, 2005 | 11:10 AM
I think Heat Rave answered your question... but I guess I'll repeat it:
Do you have an air/fuel ratio gauge in your car?
Old Oct 15, 2005 | 01:13 PM
efrain's Avatar
I've got to check. But I don't think so. I just bougjht the car like 4 months ago, so I am still getting familiar to it. As much as I know teh only extras that the car has are the one I told before: Well my NA just have headers, cold air intake, msd, ported, 60 mm TB.
Old Oct 15, 2005 | 05:26 PM
w/ a 60mm tb you could prolly increase the fuel a lil bit... but you'll deffinately need an air/fuel ratio gauge to make sure it's running where it should.
Old Oct 16, 2005 | 03:08 AM
Unless it's a wideband A/F gauge, it'll be a poor way to tune fuel. The most proper way would be to dyno it for proper FPR settings, or else gain access to a wideband O2 sensor.
Old Oct 16, 2005 | 05:37 PM
efrain's Avatar
I was looking at MSA and they have a FPR for $269.99
In ebay they have universal FPR's for $50.00. Which is the better option? Does the MSA FPR is so much different from the $50.00? Will I get the same bennefits from any FPR? MSA claims that the car will increase an avg. of 20 HP . Is that true?
Old Oct 16, 2005 | 09:46 PM
Again... it's the difference between a "Rising Rate" fpr, and an "Adjustable" fpr.
The MSA one is a rising rate, and they SHOULD HAVE put in there that it works best on forced induction cars.
The ones on ebay (99% of them are the square box w/ the gauge) are okay... but you get what you pay for.
We can offer only so much advice. Eventually you have to make a decision yourself.
Old Oct 17, 2005 | 04:11 AM
efrain's Avatar
thank you
Old Oct 17, 2005 | 08:27 AM
With the other modes you've done, I think you should leave the stock FPR and get a performance cam. Mild or medium duration (due to stock compression). There's plenty of fuel stock, just not enough air at high rpm. The cam will let the engine breath more in at those high revs.
Old Oct 17, 2005 | 03:08 PM
efrain's Avatar
Hey Bleach, the cam of a turbo 280zx will make it fpor me?
Old Oct 17, 2005 | 03:34 PM
lww's Avatar
lww
Head Muckraker
No. The cam from a Turbo will actually make things worse for an NA engine. There's less overlap in the intake and exhaust lobes because it is designed for a compressed intake charge not a vacuum intake charge.
You need a performance cam grind for a NON-turbo car. You will actually loose performance with a turbo cam in a non-turbo car.
Old Oct 18, 2005 | 08:10 AM
correct. In actuality, the stock turbo cam is ALMOST the same as the stock non-turbo. I think I remember the specs being that the turbo was ~5 deg less duration on intake but the same on the exhaust lobe.
I once told someone that needed a replacement turbo cam that the stock non-turbo would work ok because the specs are very simular. I guess I'm not totally sure on that but it should work fine.
For your non turbo you want more lift and duration. Don't go with too much lift or you need to replace the valve springs with NISMO springs that won't bind up. 0.460 lift if max. Duration should be 270-282 max. Any longer duration and the lower rpm compression is greatly lowered and you really should do something to raise compression. That would involve an engine teardown. So bascially mild cam upgrade. Stage 1 or 2 either from Crane Cams or Motorsport Auto. Also, buy all brand new rocker arms with a new cam. Don't get the USA made ones, get Japan rockers. I think Rockauto.com has them for like $13 ea. Very cheap! Other places charge 20-40 each. These are Japan made like the Nissan originals.
Other mods to do would be to remove the head, port match the ports and port the intake manifold runners and throttle body opening to match the larger throttle body. All that along with the bigger cam and then you might need some more fuel at higher rpm.
KSpakes87
Feb 26, 2014 03:21 PM
zcooks
Jan 22, 2011 01:49 PM
TeamRonin
Nov 22, 2009 10:02 PM
MistaZ31Turbo
Feb 26, 2009 08:24 PM
