Failed emissions - Any Suggestions?
Old Jun 10, 2008 | 07:58 AM
Red-Eye's Avatar
Hello,
I failed the Low Speed RPM test on my 83 280ZX, 5-speed, N/A, with 120,000 miles.
Here's the Low Speed numbers:
HC - Reading = 198, Limit = 220 ----> OK
CO - Reading = 1.49, Limit = 1.20 ----> Fail
CO2 - Reading = 14.2, No Limit on the form
O2 - Reading = 0.03, No Limit on the form
Here's the High Speed RPM numbers:
HC - Reading = 49, Limit = 220 -----> OK
CO - Reading = 0.31, Limit = 1.20 -----> OK
CO2 - Reading = 14.7, No Limit on the form
O2 - Reading = 0.41, No Limit on the form
Any help would be much appreciated. Thanks...Robert
Old Jun 10, 2008 | 08:20 AM
What's the timing set to?
Do you have a cat installed?
Have you checked the oil / plugs / plug wires / cap & rotor / sensor wires?
Old Jun 10, 2008 | 08:23 AM
Red-Eye's Avatar
It hasn't had a tune-up in quite awhile, sounds like that's the place to start. Cat is in place, replaced the muffler a couple of years ago.
Thanks...Robert
Old Jun 10, 2008 | 08:24 AM
Old Jun 10, 2008 | 09:38 AM
Red-Eye's Avatar
Not sure, haven't checked it in ages. What do you suggest?
Old Jun 10, 2008 | 09:44 AM
Check the timing (with the vac advance on the distributor unplugged). Stock timing should be @ about 8 degrees. It will put out better emissions @ 3-4 degrees (but no power at all). Set it before taking it to the shop, then reset it after you get it back from the shop.
Also make sure the plugs are clean & have proper gap... an oil change sometimes helps (if the oil is really dirty & old). Also check vacuum lines (vac leaks can throw off emissions). Just a classic tune up & setting the timing will help.
OH... and check the O2 sensor (if it's the orig, it's probably time to replace it).
Old Jun 10, 2008 | 10:02 AM
Red-Eye's Avatar
Thanks alot
007max
Feb 6, 2008 11:16 AM
lrms515
Sep 1, 2007 04:24 PM
JohannB
20
Jul 17, 2005 03:39 PM
Red-Eye
Apr 25, 2005 03:28 PM
rngrck
Aug 7, 2002 06:22 AM
