EFI or Carbs, that is the question.
Old Jun 2, 2003 | 09:03 AM
lifegrddude's Avatar
Externally Wastegated
About the car, sounds like vapor lock to me, but I dunno for sure. Fuel damper ok? Nol leaks in the fuel system? Anyway, carbs can make a good deal of power. I don't think it will be cheaper as the same things that make power in fuel injected piston cars is done to carbed cars too like head work and boring, etc. However, carbed cars can make a good deal of power, right now I'm on a trip in Japan and I've seen a few old Skylines and Fairladies that are running on carbs that have put out some nice #'s. Most I've seen is on high octane pump gas (100 I think) and he has 358hp on triple carbs. Insane to hear too, wish I had a vid cam with me. There are numerous all motor carbed Z's here pulling 11's and some in the high 10's. I say go for it if you have the experience of tuning carbs. I don't! I'm sticking to efi all the way, seems easier for me for some odd reason.
John 82ZXT
Old Jun 2, 2003 | 04:14 PM
icice9's Avatar
Super Siver & Black Stud
your problems sounds more like the ingnition modual to me then anything else.. most people dont know about that part.. its about a $100 part but i know its going to solve your problem.. its probably nevber been changed and from what youve described. it sounds like its your module.. its that lil black box attached to the side of your distributer. its a common problem on the Zs as they get older.. i had the same problem with both my 79 and 81 ZX..
Old Jun 3, 2003 | 04:47 AM
Is your fuel pressure constant? Could be the fuel pressure regulator crapping out, although I think icice9's suggestion is probably better. Is the car still running the stock coil? It could be old and not providing enough spark energy for the motor.
John 82ZXT
Old Jun 9, 2003 | 11:02 PM
icice9's Avatar
scott... the module is located on the distruber housing.. its a rectangular black box right next to it.. when you take off the cap you can get to the 2 connectors... thats one of the most common problems with the older ZXs... they go out.. most people havent changed it and the ZX is over 20 years old... so yeah.. you might wanna change that part... i had 2 ZXs and both of them had bad moduals
67chevl
Nov 10, 2013 10:17 AM
ZZzzz
Jul 11, 2012 10:51 AM
John_F
Nov 26, 2007 08:39 PM
kolts
Nov 5, 2002 05:22 PM
my78z
Aug 17, 2002 11:29 AM
