Diving into header install (with pics)
Started out pulling off the intake and stock manifold, nothing too exciting, except I found a couple missing bolts on the intake side and a sheared off stud on the exhaust side.
The one thing I'm concerned with is that some of the cylinders seem to be running lean. There are barely any carbon deposits on the #1, #3,  exhaust runners. How big of a problem could I be looking at here? Both manifolds are off, thats one greasy motor. http://gallery.azmaximas.org/albums/...0658.sized.jpg Stock exhaust manifold http://gallery.azmaximas.org/albums/...0659.sized.jpg Thats a lot of caked on crap http://gallery.azmaximas.org/albums/...0656.sized.jpg The exhaust ports #1http://gallery.azmaximas.org/albums/...0662.sized.jpg#2http://gallery.azmaximas.org/albums/...0663.sized.jpg #3http://gallery.azmaximas.org/albums/...0664.sized.jpg#4http://gallery.azmaximas.org/albums/...0665.sized.jpg #5http://gallery.azmaximas.org/albums/...0666.sized.jpg#6http://gallery.azmaximas.org/albums/...0667.sized.jpg |
Taking a closer look at the header, I noticed there are 2 ports, one for the o2 sensor and one for the EGR. It so happens my Z doesn't have the EGR system. I called MSA and the guy on the phone was trying to convince me that my Z must have an EGR system because all 280zx's came with it. My car is a 1980 model and unless someone swapped out the stock intake and exhaust in the past (doesn't seem that way) then my car never had an EGR system. My question now is, what should I do to plug up the EGR port on the header? What is the thread count on the nut - is it possible to find a fat bolt and just bolt that port shut?
No EGR means that somebody at some time in the past removed it... Rod. |
007max... post a pic of your intake manifold.
i put a bolt in mine, the only thing is i forgot the count for the threads. you can get them at a specialty hardware store, not jus the regular autoparts places. take the header with you, they can measure it there, and get you the correct bolt.
Originally Posted by RodMoyes
... The guy at MSA was right.
I forget what, but I heard that there was a rarer intake that came off the 280ZX cars that didn't have an EGR valve. It was the P-82 intake that came out of a 280ZX. From what I can gather at least from HybridZ is that many of the 79' and 80' ZX intake manifolds were EGRless for some reason. I don't know if these people were from other countries I didn't pay attention to their locations, but my guess is your car hasn't been necessarily switched.
I know that my '79 has an EGR but no O2 sensor. Here are pics of my 1979 EGR Intake, stock as far as I know.
http://i26.photobucket.com/albums/c1...0/IMG_1367.jpg http://i26.photobucket.com/albums/c1...0/IMG_1362.jpg http://i26.photobucket.com/albums/c1...0/IMG_1366.jpg http://i26.photobucket.com/albums/c1...0/IMG_1364.jpg |
EGR's piss me off. lol, but yeah post pics of your intake manifold. and teh numbers stamped on it
Pictures of the intake and exhaust manifolds. The exhaust only has one port for the o2 sensor.
http://gallery.azmaximas.org/albums/...0678.sized.jpg http://gallery.azmaximas.org/albums/...0679.sized.jpg http://gallery.azmaximas.org/albums/...0683.sized.jpg http://gallery.azmaximas.org/albums/...0680.sized.jpg http://gallery.azmaximas.org/albums/...0682.sized.jpg |
Looks like 007 is lucky and has the P-82 EGR-less intake.
^^^ and there it is! :107:
Damn you guys are quick!
So, does anyone know what size bolt I need to plug that EGR port? I already have the header mounted and I don't feel like taking it out to go shopping for bolts at Lowe's :120: |
lol, why not, its cool walking around with headers, be like yeah, this is only one, its a V12 bitches! lol
That'd be funny shit, however, it's already on the car and hooked up to the exhaust.
Time to go put on the intake and reconnect all those vacuum lines :tear: |
http://img.photobucket.com/albums/v6...X/EGR-plug.jpg
Here's the amazing plug we ended up using to plug off the exhaust side of the EGR. It was all we could find in my friend's garage that fit. |
didnt want to weld it closed?
Naa, the bolt is much cooler, and I don't know the slightest bit about welding.
know what i did? i just cut the EGR pipe in half and bent the ends so they were air tight. ill find me a bolt some other time
well at least u get a a+ for effort
i should get an A+ for effort, had had to bend that biotch by hand, that metal is thicker than you would think lol...
im actually not gonna replace that, im going to just get a better down pipe |
How bout this - shoot me an address, I'll send you the nut from an extra EGR tube I have and you can tap it for for what ever bolt you can find that will fit.:icon_super:
I believe the head of it was 7/8ths or something right around that.
