Distributor ?'s
Will a non turbo distributor work in a turbo? and will different firing orders work? currently im running 142635. I read on one of the other posts thats its 153624. do they all work the same or is one better than the other?
The distributor body is interchangeable but the internals and what not are NOT compatible between the two engines. They use two completely different means of crank angle sensing and also the turbo ECU controls timing advance/retard, where as the non turbo relies on vacuum and mechanicle means to do the same. So in short, your answer is NO.
thanks. then i have alot of n/a parts to get rid of
I saw your thread, Iam haveing dist. problems myself with my 83 280zx n/a. I got fire up into the cap but nothing out. Any suggestions ? or would you want to sell the dist you have ? This is driving me nuts.
Thanks |
| All times are GMT -7. The time now is 05:04 AM. |
