to dish or not to dish
so that completes the setup w/ addition of what nismo you said about those studs so i believe i can have a killer engine... have a missed something or is this a working... thing idea?
but wen using her as a dd couldnt i just drop the boost down to like 4 or lower to stay at 87? i dont relaly understand how this works in terms of what power to what fuel? can ya help me out?
i think any turbo motor needs premium fuel, now what if say, you turn it up to impress a buddy or chick, and you got the cheap gas in? kaa boooooom. nissan says premium right from the factory, on what, 4-7 psi stock?
well heres wut i dont understand... high boost equals high octane levels in fuel so then low or NO boost... yeah cant i turn the boost to 0 then it runs like an na rite? that means 87? or not that easy
Steven... I do not say this rudely, but it sounds like you are trying to be cheap.
Cheap costs more in the end. Just do it right the first time.
Like Shady was sayin... welcome to high octane
Originally Posted by Steven280ZX
can u put boost to 0 which means the turbo is no longer bringin in air at a higher rate?
well i gues wut im gettin at is can u "turn off" a turbo charger and be a cheap kid an put 87 octane? or by doin this increase mpg
yikes so explain to me (cuz iv never seen this done bfor w/ mi eyes) how low can u put boost?
You need to read some books
fuel efficiency depends on how well the driver can stay off the throttle.
I get about 15mpg in my 280zxt.
I've heard a lot of people say that MegaSquirt settings do allow for better mpg, but if you're boosting all the time & driving wild, ya gunna get crappy mpg.
Another thing (I don't think you mentioned it in your list) that you need is a good electronic boost controller. DO NOT buy a manual valve.
so by cuttin off boost gettin rid of mi heavy foot and megasquirtin i can up mi mpg. any other ways? i no im soundin cheap here but i wanna try for 20mpg cuz if i do a road trip down to hte msa show... yikes ther goes mi university money
Why spend all this money on building a turbo motor then go cheap on the gas? Think of it as insurance for your motor. I'm actually going with flat tops for my built motor for beter quench but no where near 9.5:1. I'm gonna keep it closer to 8.5:1. Tuning is key when running higher than 8:1 on L-motors. Not going for 20+ lbs of boost or peak HP or I would run a lower C/R.
If this is your first turbo motor then you should stick with the stock turbo pistons like already advised. It will keep you out of trouble and your motor will last.
edit: Forgot to add - Read the book
