dash "break " light comes on with accelleration
1982 ZXT auto
Whenever I accellerate the dash "brake" light come on for awhile.
I checked the break fluid and the handbreak.
Any ideas what ciuld cause this?
Thanks
Thanks
Make sure one of the floats on the brake fluid resiviors isn't stuck, if that's not it it could be the connection that tells when you have the e brake applied, and worst case scenario you have a short in your wiring some where down the line.
EDIT: nvm just put some more fluid in your resiviors and i BET you the light will go away...
^ Might need to clean the connections for the sensor. That tells you the fluid is low. Just curious. Where does your fluid level sit? It could be when you take off hard. That the fluid could be going right below the sensor spot. Anyway if that isn't it. Check your e-brake wires. Those could be not making good contact. So that it thinks your brake is on. When it actually isn't. Just remove your center console. And the carpet a little. And you should be able to get to the the e-brake wires. Good luck.
TheShanMan
Mar 8, 2014 03:25 PM
PowerhungryBill
Sep 16, 2008 09:04 AM
