Cuts out under load
Old Jul 7, 2018 | 05:59 PM
81zcar280zx's Avatar
Cuts out under load
I have an 81 280zx. When in neutral the car revs fine then when I go to drive it under load it cuts out bad. It has new plugs, wires, cap, rotor button, fuel pump. Any help with this is appreciated. Thanks
Old Jul 7, 2018 | 08:50 PM
Welcome to ZDriver!
Check TPS & plug, and CHTS & plug. Check timing. Check fuel pressure. Read spark plug tips. Report findings here.
Old Jul 22, 2018 | 04:40 PM
Timing marks
I'm trying to check timing with the light but can't see the Mark's on the pulley. I see the teeth beside it on passenger side. What kind of mark will I see? V cut mark or just a line on the pulley? Thanks in advance
Old Jul 24, 2018 | 08:51 AM
You can feel around the back edge until you find the V-groove... then mark it with whiteout.
Old Aug 5, 2018 | 07:47 AM
Timing light checked
I found the V mark and was able to check with light. I'm getting a reading where it's just below halfway up the gauge. Where is it supposed to be? Centered? At the top of gauge or the bottom? I rotated distributor and it moved up the gauge then ran worse. Haven't drove the car because nothing has really been changed yet. Thanks in advance for ur help with this
Old Aug 6, 2018 | 11:38 AM
Timing
By the looks of it the motor is out a tooth or 2 so I'm gonna buy the timing kit and replace it. Any tips to help it go easier is appreciated.
Old Aug 6, 2018 | 06:53 PM
Timing
found it, thanks. Any tips on changing timing chain? When I put the timing mark on 0 it ran worse and somewhat backfired. that tells me timing is out
Old Aug 6, 2018 | 08:56 PM
You don't need to buy a timing chain kit to "fix timing".
See this thread... https://www.zdriver.com/forums/280zx...-timing-40948/
Old Aug 7, 2018 | 06:55 AM
Reply
I have the 81 non turbo....does that make a difference in what the link describes? Or it works for both turbo and N/A?
Old Aug 8, 2018 | 09:35 PM
Same mechanical setup.
Old Sep 25, 2018 | 02:45 PM
Gas tank?
I took the car out yesterday after it had sit for maybe a month, it ran perfect....no cutting out at all....maybe the tank has trash in it to cause the issue?? Maybe where it had sat for a while all the dirt settled?
cmax417
Sep 14, 2018 11:43 AM
DJ7131
Apr 27, 2017 06:52 AM
Lupe
Jul 8, 2011 12:11 AM
mikesz
Aug 24, 2009 03:10 PM
jiyu-z-chick
Jun 8, 2006 12:37 AM
