Cruise Control Removing?
Old Oct 26, 2006 | 09:45 AM
  #26
y2daniel1981's Avatar
you sure the bogging down isnt our old (possible fuel) problem coming back to life, or is it not doing it the same way?
Old Oct 26, 2006 | 10:18 AM
  #27
Originally Posted by xtreme 2
without it all it would do was crank... even now, after putting it back on, it tries to bog down in the lower rpms... that's the only thing I've done to it too, haven't touched the rest of the motor...
Where's the pics?
Old Oct 27, 2006 | 03:27 PM
  #28
jfairladyz's Avatar
Did you remove the vacuum canister that controls the C.C.? If so make sure you plugged the vacuum lines going to the engine or you'll have a vacuum leak.
Old Oct 27, 2006 | 03:55 PM
  #29
He removed the canister, and later put it back on. Only 1 vacuum line could be found. Put now both the canister and line are back on and it's been running fine the past few days after a warm up period. Could just have just needed time for the fuel pump to pressurize
Turbo Biscuit
Mar 29, 2012 07:37 AM
harnest
Jul 15, 2010 11:38 AM
stiletto660
Aug 31, 2009 04:00 PM
cblevons
Aug 21, 2005 01:44 PM
DMT84T
Jan 3, 2002 09:04 PM
