connecting rods
Old Apr 14, 2005 | 04:36 PM
vvillium3's Avatar
connecting rods
any one here had any luck with arizona z's connecting rods??? I spun a connecting rod bearing and messed up one of the rods and crank journal. I am rebuilding basically stock motor and was wondering if arizona's rods are up to par. I am also going with arp mains,rods, and head sets with a .020 under crank. Don't really plan on going much higher then 15-17psi on the weekends. What else out there do you guys reccommend that I should consider. I am on the edge of which headgasket to use(metal or not were and which one)... Done a lot of searching but no definate answers... Let me hear your thoughts and the results of your setups...
thanks,
Old Apr 14, 2005 | 05:40 PM
DoTheDrew888's Avatar
I do not have personal expirience with AZC connecting rods but I have heard very good things about them. I think they should be fine. Also, for the head gasket you should get a Felpro. It will raise you compression slightly but not enough to cause any problems. You might even gain a little low end torque.
Old Apr 15, 2005 | 06:37 AM
vvillium3's Avatar
thanks for the suggestion... I think I will go with that, thanks for your help not too many people here wanting to help the beginners....
jason
soates4
Mar 7, 2014 06:27 PM
snwbrderphat540
Feb 19, 2009 06:13 PM
Chewievette
May 10, 2006 04:33 AM
greenmonster80
Jan 28, 2004 10:07 AM
datsun280zx_81
Jan 7, 2002 02:15 PM
