ZDriver.com
-   -   car wont start (https://www.zdriver.com/forums/280zx-performance-technical-79/car-wont-start-36392/)
wickedminded420 Oct 26, 2012 12:04 AM
car wont start
I had my car start for me the first time now it won't start it has spark is getting gas but won't fire and firing order is set correct 1-5-3-6-2-4 its a 82 280zx
NismoPick Oct 28, 2012 11:52 AM
Welcome to ZDriver! :006:
You're almost there...
An engine needs PROPER air, fuel, and spark to start.
Have you verified spark and fuel at all cylinders?
rogerz Oct 28, 2012 03:59 PM
Clean the connectors for the maf or afm, ecu and tps. Deoxit by CAIG is probably the best connector cleaner on the market. spray with CorrosionX after cleaning and before putting together this will help prevent any further corrosion.
battery is the heart of your electrical system. if it isn't aone shape you got a problem
