can I change my EFI to CFI?
Old Aug 19, 2003 | 03:16 PM
bobnagga's Avatar
I'm having trouble with my stock '82. I need to know if I can hardwire my TPS directly to the six injectors and just have CFI? I'm going to have to replace my entire harness, but I was figuring that maybe I could just scrap the whole thing and have the injectors directly run by the TPS. That would make my life a whole lot easier.
Would I run into a richness problem if I rigged it for CFI? I dont think it will effect a stock L28n/a too terribly much, but any ideas or advice would still be a great help.
Old Aug 19, 2003 | 09:01 PM
duckyz's Avatar
Man....you gota talk to Bleach or Ice for that one...............
Guys..........A LITTLE HELP HERE !!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 20, 2003 | 07:34 AM
I really have no idea what you are trying to do. I don't think the computer works like that. It reads the air flow meter, head temp sensor, and throttle position switch to meter the fuel. It would take some thinking to rig the computer to work only with one sensor.
If its that bad, make yourself a MegaSquirt computer and new wiring harness. Screw in a couple GM sensors and rid yourself of the AFM!
http://www.bgsoflex.com/megasquirt.html
Don't forget to check out the MegaSquirt Yahoo group if you do build it. Lots of people to help out.
Old Aug 20, 2003 | 09:43 AM
bobnagga's Avatar
see, what I'm trying to do is scrap the computer. I want to wire all of the injectors to the tps and use it to provide the current to pull back the needles. However, the only way I could think of to make it work is that it would constantly fire all six of the injectors. when I hit the gas pedal, it would suck that switch back into the intake, providing more current, opening the injectors further.
On the megasquirt: I was looking at that a while back, and I was wondering HOW, exactly am I supposed to put GM parts on my Datsun? that seems like it would be a little difficult. AND I'm not sure that my caveman laptop even has a serial or USB port.
I heard about this intake manifold I can buy... I forget the name of the company... but It's supposed to be a bare bones dual carb system (Like the 1stgen Z's) that will let me toss all the wiring harness and all those spaghetti lookin vaccuum lines.
Old Aug 22, 2003 | 04:43 AM
Fredrik's Avatar
I don´t think that it can be done youll need a control unit for the injectors and that is located in the ECU. Even if you got it to work you would loose ecu features like "acceleration enrichment" and risk going too lean when you´d need the extra fuel to cool your engine.
Old Aug 22, 2003 | 12:10 PM
Ya, you might as well slap on dual SU's from what you're talking about.... you'd probably much better performance than firing all those injectors all the time.
Or convert to throttle body injection like cheap american cars from the 80's.
Old Aug 29, 2003 | 08:52 AM
cerealkilla's Avatar
if you try to put cfs in a z you are in for a world of trouble. first of all you would burn your valves to a crisp in no time. second you will run the risk of possible backfire through your fuel tree and that could in burn your whole car to a crisp. your best bet is to get a stand alone fuel management system
Old Sep 2, 2003 | 06:19 AM
bobnagga's Avatar
see? That's why I ask. I wanted a second or third or fourrth opinion before I jumped right in. I appreciate all the feedback and I've decided on a hybrid. I've even narrowed down my choice of engine to a ford 302 or a dodge 340. Thanks a lot yall.
JoeGasm
Mar 8, 2008 05:01 PM
Dante
350Z Performance / Technical
18
Jan 18, 2008 07:05 PM
SportBikeMike
Apr 1, 2007 09:37 AM
speedlimits
Dec 30, 2005 11:43 PM
81 Black L28E
Mar 25, 2005 12:47 AM
