Cam
Old Feb 17, 2005 | 07:09 PM
Skully's Avatar
Cam
so i took my n42 apart...and i took the cam out...i tought cams had bearings like the crank does...i didnt know the cam mounts are just one aluminum piece...so if i get a turbo cam, will my aluminum mounts work with it?? like are the cam grinds just different or are the mounts different too??!?!! i need a BAD valve job..there is **** baked on there left and right...layers of carbon...god that engine never ran right!
also do you guys know a reasonable place for a good rering kit...i need the whole deal..bearings, seals, plugs, everything...
Old Feb 18, 2005 | 12:07 AM
lww's Avatar
lww
Head Muckraker
Don't worry! Only the lobes are different. The cam towers are the same and will require no modifications to take a turbo cam.
Now the question is, why do you want a turbo cam? Are you going to turbo your NA motor?
Old Feb 18, 2005 | 04:28 AM
Skully's Avatar
yes thats what im doing
Old Feb 18, 2005 | 08:58 AM
Aren't you going to just get a p90 head and stick it on your "NA" F54 block and rebuild it with dished turbo pistons???
I saw a webpage showing the stock lift and duration of the NA and turbo cams for 1981. They are almost identical. The differences in duration on just the intake were very small. I would say that a stock non-turbo cam works fine in a turbo motor.
If I remember right, the turbo cam has 5 deg less duration on the exhaust but exactly the same on the intake. lift is the same on everything.
Old Feb 18, 2005 | 02:10 PM
Skully's Avatar
oh..sweet hahaha.,..no ive read that n42 works fine just as long as i have the turbo pistons to lower compression....some dudes from other sites been running with n42 for years with no troubles...iw as gonna get p90 because for some reason i TOUGHT i had a p79 with round ports...but i dont
Old Feb 18, 2005 | 03:09 PM
Skully's Avatar
here is some pictures..... i need to go and get a spring compressor so i can take the valves out...
just click...
My Larger Plug hole...its already larger...and was leaking...so...make it more large??!!!
CAM SHOTS
EVEN WEAR
Old Feb 19, 2005 | 03:54 PM
Skully's Avatar
ok another quick Q....
i took my valves off...
how do you get the valve guides out? there is a lil clip at the top and i cant get the clip out with ANYTHING!!! tips?
