any one here supercharged???
Old Apr 28, 2005 | 02:58 PM
Jerkif's Avatar
yeah i was wondering if any one has taken the supercharge route and how they like it cause im thinking about supercharging cause its a little costly but i want the power and plus it should be easier than turboing right now by looking at everyones problems with turboing.
Old Apr 28, 2005 | 04:22 PM
s/cL3.0's Avatar
Bleach is my Hero
The best way I found to do it was with a procharger but it was not enough power and about the same price.. I am building a 450WHP turbo motor with SDS stand alone for about 3500.00 includin the cost of the engine..
Old Apr 29, 2005 | 01:13 PM
Jerkif's Avatar
well also is there only a limited amount of superchargers i can use. and did it do anytihng for the car when you procharged it.. like what was the main difference or was it really not worth it at all.
Old Apr 29, 2005 | 02:06 PM
DoTheDrew888's Avatar
Go to www.hybridz.org and search for it.
Old May 2, 2005 | 07:39 AM
s/cL3.0's Avatar
Bleach is my Hero
No I never went forward with it because of the cost and Hp issue. I am building for 450-475WHP a supercharger cannot provide that for me as cheap as turbo.And the turbo I am using has an effieciency of 76% at 18PSI so its not that far from s/cing.
Old May 2, 2005 | 01:13 PM
I don't think i've ever heard of anyone getting over 400hp on an L28. Are you sure you aren't over-estimating your numbers? I'd like to know what mods you are doing in order to reach that number. Also, there is no way that the rest of the drivetrain is going to be able to hold that power. You are talking serious modifacations man and a heck of a lot more than $3500.
Old May 2, 2005 | 02:16 PM
jfairladyz's Avatar
Tuned properly, over 400 is completely possible. I think there was even a L28ET in that Z magazine that was putting out like 450. Some of those old ZX racers used to put out 500-600HP turbocharged. So it's doable, and those engines were completely balanced and blueprinted with quality internals and some really good tuning. So it's definitely possible. They mentioned those cars in this Datsun engine book I have.
But yeah, you're looking at some serious dinero. The L's are tuff from the crank down, and use a turbo block, they are more rigid and have better coolant flow around the cylinders.
Supercharging would be different, and those numbers are achievable with a supercharger. But it would be far easier with a turbo setup, not neccessarily cheaper though. Supercharger don't need all that custom exhaust work and most are self contained when it comes to oiling. Powerbands alot more friendly for your daily driver too. And that $3500 will probably only cover the supercharger itself. That could get you an entire turbo setup.
I'd still turbo though.
Old May 2, 2005 | 03:04 PM
RodMoyes's Avatar
Doesn't post much...
Yes, there was a car in the Z magazine putting 450 to the wheels with a turbo l28 motor. I've seen the car in person (he's also in San Diego), and it's very real. Also, you'd be surprised what the drivetrain in that car can handle. My buddy with tthe 383 stroker motor in his Z is proof of how strong that car is. He put's out terrifying horsepower with that car and puts it to the ground via the original rear end. He had a chevy rear end in it, but it kept grenading... out of desparation one day he put the stock rear end back in, and has been running it ever since. To give you and idea of how fast his Z is... his other car is a 2003 Corvette Z06 and he calls the vette his "Slow car" and that's no bullS*&t!
Rod.
Old May 2, 2005 | 08:48 PM
s/cL3.0's Avatar
Bleach is my Hero
Do a search for clifton over at hybridz.org he is helping...My engine will be using a t-60, turbo electric boost controller, SDS stand alone, fully ported and polished head, snieder valve springs, forged pistons, fully lightened and balanced bottom end, light wieght{10lb} flywheel, CFDF clutch, and LSD out of 87 300zx. Fun fun
Old May 3, 2005 | 06:06 AM
What are you expecting the overall cost to be? I wish I had enough money to do all that haha.
Old May 3, 2005 | 06:28 AM
s/cL3.0's Avatar
Bleach is my Hero
I will let you know at the end of the month.. The most expensive is the SDS 1500.00 with coil packs, and the turbo 750.00 NEW All the machine work is being done as a favor by a friend {you scatch my back I will scratch yours kinda thing} but I am paying the shop cost price on parts I think i'm looking at 3500.00 Tops for everything.
Old May 3, 2005 | 07:36 AM
ya, if you can get an R200 LSD for free. Those things run about $500-700 these days. What about injectors, fuel pressure regulator, $800 intercooler, custom intake pipes, modified or custom built exhaust manifold for your T60, fuel rail, new fuel lines to the tank, fuel pump, NISMO seat belts, and neon foot pedels?!?
Old May 3, 2005 | 08:06 AM
s/cL3.0's Avatar
Bleach is my Hero
I have had the LSD for about 2 months I paid 250.00 for it..I have a set of 550 cc injectors that came with the motor a fuel rail that needs to be tapped for the injectors, I was told no FPR was needed with SDS {dont know bout that I am still looking} The hotside of the turbo is T4 and will bolt on as done by Clifton on hybridz, and my favorite part.... My nieghbor does fabricatoin/welding so he is making my intercoller and all the piping and also the rest of my exhaust for free... well I had to sand down hi hole 49 chevy pickup and get all the surface rust off it {it was left out in the rain for 5 minutes in bare metal form } But its worth it. Havent figured out the fuel pump, probably holley electric. I will be posting pics later as well as reciepts..COMPRESSOR SPECS:T04S housing flow: 61 lbs/min 781cfm .70 A/R housing 60 TRIM wheel TURBINE SPECS:T3 .63 A/R housing HIGH FLOW 76 TRIM stg 3 wheel {Sorry I posted the wrong turbo} here are the pics.
Attached Thumbnails any one here supercharged???-mvc-667s.jpg   any one here supercharged???-zcustomdownpipe.jpg
Old May 3, 2005 | 12:14 PM
OK that makes much more sense. You're not building a 400hp L28 turbo for $3500.
With all the parts you already have, and all the thousands of dollars of free labor you're getting, you only have $3500 left to spend. That's a bit more accurate of a claim.
Old May 3, 2005 | 12:23 PM
s/cL3.0's Avatar
Bleach is my Hero
Yeah, You just gotta love favors, I can make a living off of favors..
Old May 3, 2005 | 03:27 PM
lww's Avatar
lww
Head Muckraker
Bleach is correct.
Real cost to do it (without favors!) is going to run at least $6k and probably closer to $8k and for a REALLY bullet proof setup $10k.
Old May 3, 2005 | 05:12 PM
s/cL3.0's Avatar
Bleach is my Hero
Originally Posted by lww
Bleach is correct.
Yeah I know I love it.. HA HA If anyone wants to move to AZ I can get it done for you for the same price..
Old May 3, 2005 | 05:49 PM
jfairladyz's Avatar
It's a Nissan engine, it can be built to take anything. Their blocks, with the exception of the newer ones, have been shown to withstand some pretty wicked numbers, some even with stock bottom ends. I hear the VQ engines are pretty easy to grenade though.
Old May 3, 2005 | 06:18 PM
Are you planning on using the stock intake manifold and throttle body? All the high HP Zs ive seen use custom intake manifold and 240SX TB. You've got me interested in this project of yours haha.
Old May 3, 2005 | 09:31 PM
s/cL3.0's Avatar
Bleach is my Hero
More than likely I am going with just the stoxk manifold{ported and polished runner} and the 240sx TB. I have seen many a Z push 500HP with a stock manifold I actually think that is its limit.. I cant wait you guys asking me these questions has a grin posted on my face all day.. I have been hording parts for 4 months now and in 2 months {at most} My ZX will be done..
Old May 4, 2005 | 04:20 AM
HI; I am in Mesa, Arizona where are you located?
Old May 4, 2005 | 06:06 AM
Are you doing to do the work yourself or pay someone to do it? If you are doing it yourself im betting it will be longer than 2 months. There are always snags and things you don't expect along the way. But good luck with it man. You have to post some dyno numbers and pictures when you are done!
Old May 4, 2005 | 06:55 AM
s/cL3.0's Avatar
Bleach is my Hero
Yeah I cant wait to hit the dyno.. I am having a friend do the head work while I am in FL but as of right now I only work 4 hours a day so I have all kinds of free time to work on my car, So it should be 2 months MAX ..But about the snags I was taking off the water inlet pipe water and one of the bolts snapped off and is stuck in the head so that has to be drilled out now..
Old May 4, 2005 | 11:38 AM
jfairladyz's Avatar
I got it. Don Devendorf's Electramotive 280ZX put out over 650HP with the L28ET. That's a full blown race car mind you, but if the engine can handle that kind of abuse it will definitely handle anything you can throw at it on the street.
Oh, and no he was not running the stock intake manifold or fuel system. But he did still have the distributor mounted in the stock location. Which is something that was said to hinder the high RPM performance of the L28, but apparently, it wasn't that much of a hinderance, 650 horses, good God!!!
Still any doubters on the potential of the L28. And has anyone ever seen the O.S. Giken head? Dual cam for the L28. Don't know if they still make it or not though, but that would be wicked.
Old May 4, 2005 | 11:52 AM
s/cL3.0's Avatar
Bleach is my Hero
there was something about that head floating around lately I think it is 10,000.00 on a group buy.. Dont think it is worth it..
