Which air filter method is better for performance?
Old Sep 21, 2007 | 02:36 AM
Heat Rave R's Avatar
The new turbo I'm installing will have 4" tubing for the intake side (vs. the stock 3" tubing). If I put a 4" air filter on the end of the tubing, it will end up being placed where the AFM is, right next to the radiator, sucking in all that hot air. On the other hand, I can run a reducer on it to make it 3" tubing again and be able to put the filter in front of the radiator, where there's significantly cooler air.
So the question is, which method would perform better, the larger filter that sucks in hot air, or a more restrictive diameter filter that sucks in cool air?
Old Sep 21, 2007 | 05:19 AM
lww's Avatar
lww
Head Muckraker
Enlarge the hole in the radiator support by 1". Hot air sucks!
Old Sep 22, 2007 | 01:19 AM
rxKaffee's Avatar
does the ZXT have the stock filterbox in the same position as mine, infront of the radiator? I just hacksawed the box off of the assembly and used the existing metal hard tubing to hold my cone filter
Old Sep 25, 2007 | 12:25 PM
The stock airbox is only a 3" dia, so that doesn't solve the question of 3" filter in front of the radiator vs. a 4" filter that sucks up hot air.
Old Sep 25, 2007 | 12:49 PM
duowing's Avatar
NisTuner
I'd think it wouldn't matter. Hot air is hot air, and cooler air is always going to be better going through your intake than hot air.
LemonHead
Nov 13, 2012 08:53 PM
silverray76
May 12, 2011 08:55 AM
uztv
Nov 18, 2002 04:40 PM
liebl
Aug 27, 2002 06:57 AM
skelator
Jul 11, 2002 12:02 AM
