83 N/A won't idle
83 N/A won't idle
I am looking at a 83 NA that has great compression but has difficulty ideling.
Owner has replaced the following: Throttle position sensor, AFM, Chts, Fuel pressure regulator, fuel pump and filter. Car is low mileage.
Anyone had this issue? Any ideas where to start ?
Thanks
Glenn
Thanks
Glenn
A vacuum leak is the usual culprit. Disconnected vac line, or crack in the AFM boot, PCV / valve cover hose. Also could be: the cold start valve, air regulator, timing, or someone messed with the preset idle screws.
FastZ
11-09-2015 03:03 PM
AllenBC
11-09-2015 10:11 AM
bojo68
02-26-2010 05:40 PM
