'82 280ZX no sparking
Old Apr 16, 2016 | 07:29 PM
ermracing's Avatar
Hopefully we have overlooked something basic here. I have an 82 280ZX engine in a '91 Mustang (don't ask...) It has dual carbs so the only thing I need it to do is create spark to the cylinders. The coil we have is from a 78 280Z that was working just fine until the previous engine overheated and we discovered just how long it would run with water lubricating the cylinders. Anyway, I have 12v and the B wire from the dizzy module going to the + side of the coil, and the C wire from the dizzy module. I put on a new cap and rotor but there is no spark from the coil wire or (obviously) the plug wires.
Is this the proper setup? Is the distributor module dead? Is there a way to test it? Any help would be welcome.
Dave
Old Apr 18, 2016 | 08:02 AM
Are you running a stock distributor? Have you checked the stator?
And you should post some pics of this thing!
Old Apr 18, 2016 | 08:39 AM
ermracing's Avatar
Stock distributor. I will check the stator. Just a visual check or is there some electrical way to test it? I guess my main question is, should this setup work without all the f/I stuff?
Here is the car in action....
Old Apr 18, 2016 | 02:57 PM
ermracing's Avatar
I removed the stator and the magnet is broken around one of the bolt holes and there appears to be a small crack, but it's all there. Time for a new one?
Here is the distributor mounted on the engine:
This is the whole thing:
Dave
91Zman
13
Feb 20, 2006 02:46 PM
