79 280 ZX only starting gives an issue
Old Jan 5, 2015 | 02:11 PM
1979 280z's Avatar
After the z warms up it is fine. I have to feather the gas to get it to start for about 3 mins and hope it doesn't die to start the feathering all over again. I just swapped the motor and the old one didn't do this. Seems like the fuel light wants to bounce off and on when I am trying to start. Any help appreciated.
Old Jan 5, 2015 | 02:58 PM
zxguy1986's Avatar
Welcome to ZDriver!
Wish I knew more about the S130 but if you had a Z31, I would suggest you check out the air regulator for the 2 solenoids which control your idle speeds, cold and fast. Let our S130 guys give you their input. Sounds like a common issue and probably has an easy solution.
If you don't already have your freebie factory service manual and the other cool docs available at XenonS130 - S130 Reference download them and check them out. Your FSM has a lot of easy to follow inspection and troubleshooting pages that may be of some help while you are waiting for other suggestions.
Thanks and welcome again.
Unorthodox
Oct 11, 2013 11:15 AM
GreenMachine
Jul 29, 2012 08:09 AM
Lesnocker
Feb 11, 2011 01:13 PM
OpenRange
Aug 26, 2009 12:54 PM
280z racer
Sep 25, 2007 11:29 AM
