3.1 turbo?
Old Aug 10, 2006 | 01:53 PM
Steven280ZX's Avatar
3.1 turbo?
hey guys im wondering, msa has this cam kit and a big bore kit that'll up ur engine to a 3.1. if i where to turbo this setup with a garret t4, will it work or will ther be engine failure. i gotta 82 na fi manual tranny btw. lemme no what ya think.
Old Aug 10, 2006 | 03:22 PM
T4, and a stroker kit? You seriously have $6000+ to spend on building your engine right now?
Old Aug 10, 2006 | 03:40 PM
jfairladyz's Avatar
as long as you go with low compression pistons then it's no problem to turbo the stroker. But you will have to put a considerable amount of money into the setup. You'll have to have the block machined to accept the bigger pistons and clearanced for the rods (needs to be done anyways). You'll either need an L28ET to start with as it's already set up for a turbo, or you'll need to do a lot of fabbing to make the turbo setup work with your non-turbo motor. Either way a little modding will need to be done to accept a T4.
If you're going to turbo it though then stay away from the cam kit. It's only worth the money on a non-turbo motor.
Old Aug 10, 2006 | 04:04 PM
If you want to do a turbo stroker correctly, check this guy's L28ET Stroker: http://www.angelfire.com/extreme/280zxt/
Here's another thread about the stroker:
http://zhome.com/rnt/3.1HanveyProject.htm
Old Aug 10, 2006 | 06:48 PM
KTM200-280zxt's Avatar
Do you have any money you could lend me while your at it?
Old Aug 10, 2006 | 07:21 PM
lww's Avatar
lww
Head Muckraker
Jeff Priddy has well over $40,000 in his car and he's done probably another $100,000 worth of research and work on his own. When he's finished, he couldn't get his investment out unless he can get $200k out of his car.
Clearly, that will never happen. He doesn't do it to flip it at a Barrett Jackson auction.
Here's the most important quote straight from the ZHome.com link above:
"Bottom line, plan on over 5K to do it right. You can do it for under 2k, but you take some chances of reducing your longevity, power producing capability, etc... With stroker motors, it is a crap shot. For those looking at turbo strokers, I will tell you, NO ONE has built a good turbo stroker, because it costs too much to do both well. Well, apparently there are some getting close to doing both well, but that is still up in the air. Those that did try, skimped in the stroker part, because the turbo is what produces easy to see power. If you want a turbo, stick with the L28, unless you just have money to throw around, and want the ultimate power. In that case, throw a few grand my way! So what is important for the stroker? In order of importance, in my humble opinion:
1) The best machine shop you can find, (not afford, find, for if you can't afford it, then you are throwing money away).
2) F54 block. 3mm overbore is HUGE! Keep some of that strength.
3) Balance, Balance, Balance the rotating assembly. Enough said.
4) Money, lots of money.
With those, you will have a good start. Do lots of research, and pick the brains of everyone you can. You will start to get a clear picture when you do. - Good Luck!"
P.S.
Unfortunately, this will have to be my last post on ZDriver.com. I just realized I was at 1,999 posts and I don't want it to click over to 2000. The thought of having to post another THOUSAND messages is just too daunting... Thank you Mrs. Calabash - wherever you are. Good Night!
Old Aug 10, 2006 | 08:43 PM
skittle's Avatar
Taste My Rainbow
hahahaha lww very funny
Old Aug 10, 2006 | 08:47 PM
well i figured id be spending about 6k actually... so if i got a F54 block and a turbo head w/e its called... 89mm pistons, new rods, crank, turbo, and hell lets throw in a cam, she'll work? and wait doesnt the garretT3/T4 hybrid thing bolt rite on?
Old Aug 10, 2006 | 09:11 PM
jfairladyz's Avatar
The T3/T4 hybrid turbo will bolt right onto the L28ET exhaust manifold, yes. But a standard T4 turbo will not. It needs the T3 exhaust housing to bolt to the manifold.
Old Aug 10, 2006 | 09:14 PM
yeah on the setup i was thinkin about i ment a t3/t4 sorry guys i messed up there. but it'll work?
Old Aug 10, 2006 | 09:15 PM
jfairladyz's Avatar
The T3/T4 is a great turbo to go with. Great spool up and more top end. Nismopick is using a T3/T4 so he should be able to tell you how it works out on the L28. But it definitely works.
Old Aug 10, 2006 | 09:19 PM
Indeed... but remember Steven: If you shove in more air, you also need more fuel. I'm still using the stocker 260cc injectors, and have them pretty well maxed out. I've got some 370cc's that I'll be using w/ a SAFC soon.
Proper A/F mixture is your best friend!
wow ur telling me this can work!?!? and all this time i thot i was dreamin!
Old Aug 10, 2006 | 09:21 PM
oh yeah right i fergot about uppin the injectors i thot HKS 370cc would do the trick and wen i got rich again after all taht spendin id grab a custom fuel rail
You need to get out more There's lots of webpages of guys doing upgrades to their L28ET.
Old Aug 10, 2006 | 09:23 PM
i no but do u really want me to do all that work wen i can create mi own thread where i get all the info i want in one place? come on
Old Aug 10, 2006 | 09:24 PM
He that does his own research, becomes wise! HeHe... we'll guide you to build a monster Z if ya not careful.
Old Aug 10, 2006 | 09:26 PM
isnt what i just said a monster Z?
Old Aug 11, 2006 | 07:41 AM
You seriously do need to do more research then ask quesions. You should be able to find 3.1 stroker articles online. I really don't see the point.
Its just to say you're using an L-series engine? If you want 500hp, buy an RB with your $5000 then you've still got money left over. L-series are old technology.
Old Aug 11, 2006 | 02:36 PM
lww's Avatar
lww
Head Muckraker
Seriously, Bleach is absolutely correct. The amount of time and money you'll spend on a 3.1L Turbo, could be better spent on serious head work, custom exhaust & downpipe, a fat turbo and a custom baffled oil pan.
Old Aug 11, 2006 | 06:12 PM
Skully's Avatar
like yea eh....dirty manitoban.
Old Aug 11, 2006 | 10:37 PM
silly manitoban, get yur head out of the clouds. actually, if your gonna build it, go big, then you will only have to do it once. the rb requires fabrication, so if your not up to that task, then go l28et. its really up to you steve, and the questions you ask. inform yourself on all the options, the you can make a very educated desision
Old Aug 14, 2006 | 02:54 PM
ok ok i did sum looking around and......... u guys r rite i dont no wut i was thinkin... yet another question then i figure doin a turbo swap is appropriete, what is a reasonable thing to do to the turbo engine to improve performance?
Old Aug 14, 2006 | 05:12 PM
duowing's Avatar
NisTuner
One thing I don't understand is why is everyone wanting to go the way of the turbo'd stroker, etc. You can build some pretty nice power from just that turbo engine alone for way less and you'll be putting out enough power to pretty much outrun just just about anything normally on the streets/freeway, not to mention have a pretty quick drag car.
To improve performance in the turbo engine, you can get a boost controller so you turn up the boost, but if you're going to do that you'd probably want to get an intercooler. Little stuff like that will let you push out more boost and get more horsepower. Bigger injectors to support more boost. I believe even the Z31 ECU swap which can be done for pretty cheap would be a step on the right direction.
Melspace02
FS: 300ZX (84-89)
Sep 5, 2012 06:28 PM
Spyder Z 15
Aug 20, 2008 12:28 PM
johnsonsz31tt
May 7, 2008 07:27 PM
thunderz
Feb 12, 2006 06:46 PM
teamadidas
Jun 2, 2005 04:41 PM
