ZDriver.com
-   -   280zx underbody exhaust/drive train problem? (https://www.zdriver.com/forums/280zx-performance-technical-79/280zx-underbody-exhaust-drive-train-problem-42068/)
cullenmichael34 Mar 17, 2017 06:36 AM
Hello everyone. 1982 280zx n/a manual.
I've searched and can't seem to find the answer to this problem, mostly because I don't know where to even start. I have 2 issues, possibly related.
1) This is getting worse, but the car seems to struggle accelerating when I goose it in 3rd gear or above.
I will shift into gear, hit the throttle, the rpms will jump again like they would in an automatic, but I'm already in gear.
They then settle back down and I can accelerate again.
2) when driving, there is a pinging sound under the car that changes tones with speed and gear. It doesn't affect the motor or appear to affect driving, but it sounds awful. I'm thinking it is a loose exhaust.
Any help would be appreciated. Thanks!
NismoPick Mar 17, 2017 06:50 AM
Well what have you checked? When was the last time you did a tune up? A basic tune up will do wonders for a tired motor: plugs, wires, cap, rotor, check sensors & connectors, etc.
All this is detailed in the FSM: XenonZcar.com S130 Factory Service manuals
cullenmichael34 Mar 17, 2017 06:58 AM
My apologies but I just found the rattle. It was coming from a rusted heatshield. I'm thinking the rpm jump might be a sign that my clutch is going out? Just replaced the cap and oil but I'll try plugs and wires first. I've never replaced the clutch so I may look into that as well. Thanks!
NismoPick Mar 17, 2017 07:11 AM
A clutch starts slipping once it's worn out... So you hit the gas, rpms jump, you no go. :)
cullenmichael34 Mar 17, 2017 07:33 AM
Oh, it might not be that then because I'm picking up a loud, resistant hum from the rear end of the car. It reminds me of the time my u-joint went out. Sorry about throwing all of these problems out there
