280ZX Turbo: Let's go faster!
Old Jan 27, 2004 | 12:59 PM
hellzbellz83t's Avatar
Knock yourself out, dude!
Keep us posted...
-Kel
Old Jan 27, 2004 | 02:30 PM
91zxtt's Avatar
My knowledge is more on the Z31's and Z32's, but that seems like a lot of boost. A lot of fun, but a lot of boost. When you think about it though, what fun is a project without running the risks of total and terminal detonation. Definitely keep up posted. Take pictures as you go and post them here. That will be one BMF.
Old Feb 2, 2004 | 08:21 AM
I was under the impression that the stock Nissan T3 was not even capable of 20psi or higher... no matter what the fuel and cooling capabilites are. Don't they max out around 13-15psi? Or was that something to do with the maximum boost with the stock fuel injection.
If a T3 can put out 20psi, then why do so many people upgrade to larger turbos?
T3/T4 hybrid is different.
Old Feb 5, 2004 | 10:38 AM
preith's Avatar
Detonation is only the companion of the lean
This threw me for a loop. I may be way off base here, but detonation can easily, and in my eyes most likely be caused by incorrect timing?
Old Feb 6, 2004 | 10:58 AM
Very good info, thanks!
I've got a question. The turbo L28 has different distributor that is controlled by the ECU. If someone (like me) were to go with an aftermarket fuel management computer, could a n/a distributor be used since the turbo dizzy won't work without the OEM computer?
...or basically, are there major differences in ignition timing curves on turbo vs. NA?
Old Jul 18, 2022 | 07:23 AM
ViperFred's Avatar
Smile Good plan
Step two: Let me know where you get the oval hole saw.
Seriously though, I wish I had your skill set. My '83 is a dog though a blast to drive.
Vtec Killer!
May 20, 2008 08:21 PM
Jerkif
May 29, 2005 03:09 AM
krovisser
Jun 27, 2003 02:36 PM
ViperDiablo24
Nov 5, 2002 08:11 AM
zkyle
Dec 9, 2001 11:25 AM
