280ZX Turbo HEI Swap Schematic,Please?
Old Aug 9, 2015 | 02:21 PM
Wingnut 280ZXT's Avatar
Yo Z-Buffs.... The turbo Z's ignition control module is insanely overpriced as you all know,hence why you all do the GM 4-pin HEI ignition module swap in your Turbo Z's...I'm having troubles finding a good,clear schematic of this setup. Also,does the GM module need to be mounted to a heatsink,like the factory unit is? Or does it dissipate the heat ok on its own? Pics of fellow Z owners who have done this swap successfully would be super too! I realize this isn't rocket science,but I don't want to zap my brand new module either! lol... Cheers and Thanks In Advance!
Old Aug 10, 2015 | 07:50 AM
Like this one? Been around for years... https://www.zdriver.com/forums/240z-...evy-hei-27569/
The only "error" on that pic is the Black w/ White stripe is switched power, not ground.
Old Aug 10, 2015 | 01:08 PM
Thanks Nismo! I knew I had seen that thread but had troubles finding it... Fingers and toes crossed... Cheers!
Old Aug 10, 2015 | 03:19 PM
Skully's Avatar
Make sure you ground it good, not just its body, but run a wire from the bolt to the chassis. Heat-sink and thermal compound is cheap insurance. Buy a few, I have 2 in my glove box at all times. If they are too expensive local, just order a few online, they are fairly cheap.
jaromgi
Jul 23, 2013 08:10 AM
83turbo280zx
Nov 30, 2012 07:25 PM
abcsgarage
Jul 28, 2011 08:09 PM
benny127
Sep 13, 2010 12:13 PM
kijana
May 17, 2007 03:48 PM
