280ZX radio
Old Oct 26, 2008 | 05:36 PM
ZBRICK's Avatar
280ZX radio
I can't believe it. The AM works great but all of a sudden the FM only works sometimes. It doesn't matter what station you try to select on FM it just dosen't work consistantly. Any thoughts?
Last edited by NismoPick; Oct 26, 2008 at 08:22 PM. Reason: fixed the speeeling of "radio"
Old Oct 26, 2008 | 05:39 PM
Ratfink's Avatar
Hoov for Pres!
Something loose? Check the antenna. Sounds like it's rubbed against something, or it's coming loose.
Stock stereo?
Old Oct 26, 2008 | 05:41 PM
ZBRICK's Avatar
Yes all stock
Old Oct 26, 2008 | 06:15 PM
Ratfink's Avatar
Hoov for Pres!
You're gonna have to do some investigating man. If it's something that happens once in a while, and it is not constant, I am guessing that there is a loose conenction. AM band uses a coil inside the radio most of the time. FM uses the external antena. So, my guess is the there is something loose between the radio, and the antena. Only way to find it is going to be to do some work.
I don't know of any common weird problems with the factory radio that makes the FM band go out alone.
Upgrades are always a consideration. Or are you trying to keep everything factory? Installing a new system is not hard to do. I could not stand stock radios even in new vehicles. But, that's just me.
Old Oct 26, 2008 | 07:16 PM
ZBRICK's Avatar
Thank you. Want to keep it stock as much as possible. I'll check the wire connection.
Old Oct 26, 2008 | 08:12 PM
280zx2by2's Avatar
Haterade by da gallon!
or you could just do this...
and its sad i have a perfectly good radio in my garage, my tape deck was busted so it was time for an upgrade...
Old Oct 26, 2008 | 08:26 PM
I think he just said he wants to keep it stock.
Old Oct 27, 2008 | 03:15 PM
ZBRICK's Avatar
2by2, Ya, I want to stay stock as much as possible. You did a good job though. I've seen to many "upgrades" that have a tacky looking replacement for the silver panel. Good job
Old Oct 27, 2008 | 05:38 PM
Ratfink's Avatar
Hoov for Pres!
They have this at MSA..
http://www.thezstore.com/page/TZS/PROD/IA42/50-1290
Kinda cool.
My thing is this. With a mint condition numbers matching Z, it's just not going to be a big investment. But, if you want it like that for the style, or for taste, then more power to you. This is probably the only car made in the 70's or earlier that I wouldn't feel bad for molesting it. haha
If it was a numbers matching 1971 Plymouth Superbird, I would not. haha
Old Oct 27, 2008 | 06:50 PM
Brewski*'s Avatar
I have a stock 79 it did the exact same thing. Then eventually the FM went completely and now the AM too. I think it is internal ic issue.
Old Oct 27, 2008 | 07:47 PM
z-hag's Avatar
Queen of Yachts
is stock stereo in 280s also clarion, as in the z31s??
if so, there are places that rebuild/restore whate3ver these4 radios---repairable in some places--have you sought out those shops??? i was going to do tha twith the one in the AE, but is working perfectly....goood luck....btw- i sent a pm...
Old Jan 4, 2009 | 05:02 PM
ZBRICK's Avatar
This situation is bazzar. I have not been able to figure out the problem with the radio. as mentioned above, FM is intermittent, AM works all the time.
Now that it is cold outside, i'm sure you can imagine the heater could come in handy, but it works intermittently. The bazzar part is that when the FM does not work neither does the heater and when the he FM is working so does the heater and visa vera. WTF, WTF again
Does anyone have a clue regarding this issue and what to do to fix it?
Old Jan 4, 2009 | 07:56 PM
When you say "the heater isn't working" do you mean the blower, or that there is no heat coming out when the air is blowing out of the vents?
Old Jan 6, 2009 | 05:14 PM
ZBRICK's Avatar
The blower is not working.
Old Jan 6, 2009 | 06:36 PM
skittle's Avatar
Taste My Rainbow
then its time to prob pay her.. lol j/k could not help myself on that one.
Old Jan 6, 2009 | 06:49 PM
ZBRICK's Avatar
LOL, I guess my z finally had a problem that you all can't figure out. Score one for my z. She still isn't blowing or signing FM though. I didn't know you guys could sleep knowing there is a problem out there that you don't have an answer to?
Old Jan 6, 2009 | 07:17 PM
280zx2by2's Avatar
electronics are tricky!!!!
btw do you have a local J-yard with a zx? i have 3 in mine and 2 of them have(i assume) working radios...
good luck
Old Jan 25, 2009 | 11:52 AM
zfreak1981's Avatar
radio
im needing the factory radeo for a 83 280zx if anyone has one for sale
Old Jan 26, 2009 | 10:12 AM
I have one available. I'll test it first.
Old Jan 27, 2009 | 03:05 PM
zfreak1981's Avatar
radio
cool, thanks bro. let me know how much
Old Jan 28, 2009 | 04:56 PM
zfreak1981's Avatar
radio
any luck on the radio?
Old Jan 28, 2009 | 07:55 PM
I just tested it. No power at all, sorry.
Radio and tape don't respond.
Old Jan 29, 2009 | 09:19 AM
zfreak1981's Avatar
radio
its cool man. thanks for trying
Old Jan 31, 2009 | 08:10 AM
zfreak1981's Avatar
does anyone have the triple gauge cluster for the oil pressure,voltage meter and the clock setup? i would like to buy it from you if it works. i cracked the board on the back of mine iv looked on ebay and tried to get in touch with zbarn and tried local junk yards but no luck.
Old Feb 2, 2009 | 11:36 PM
Z Car Barbie's Avatar
User Friendly
Try this website, ZFreak: http://car-part.com
