ZDriver.com
-   -   280ZX radio (https://www.zdriver.com/forums/280zx-performance-technical-79/280zx-radio-27084/)
ZBRICK Oct 26, 2008 05:36 PM
280ZX radio
I can't believe it. The AM works great but all of a sudden the FM only works sometimes. It doesn't matter what station you try to select on FM it just dosen't work consistantly. Any thoughts?
Ratfink Oct 26, 2008 05:39 PM
Something loose? Check the antenna. Sounds like it's rubbed against something, or it's coming loose.
Stock stereo?
ZBRICK Oct 26, 2008 05:41 PM
Yes all stock
Ratfink Oct 26, 2008 06:15 PM
You're gonna have to do some investigating man. If it's something that happens once in a while, and it is not constant, I am guessing that there is a loose conenction. AM band uses a coil inside the radio most of the time. FM uses the external antena. So, my guess is the there is something loose between the radio, and the antena. Only way to find it is going to be to do some work.
I don't know of any common weird problems with the factory radio that makes the FM band go out alone.
Upgrades are always a consideration. Or are you trying to keep everything factory? Installing a new system is not hard to do. I could not stand stock radios even in new vehicles. But, that's just me.
ZBRICK Oct 26, 2008 07:16 PM
Thank you. Want to keep it stock as much as possible. I'll check the wire connection.
280zx2by2 Oct 26, 2008 08:12 PM
or you could just do this...
http://i286.photobucket.com/albums/l...CN0274-1-1.jpg
and its sad i have a perfectly good radio in my garage, my tape deck was busted so it was time for an upgrade...
NismoPick Oct 26, 2008 08:26 PM
I think he just said he wants to keep it stock. :D
ZBRICK Oct 27, 2008 03:15 PM
2by2, Ya, I want to stay stock as much as possible. You did a good job though. I've seen to many "upgrades" that have a tacky looking replacement for the silver panel. Good job
Ratfink Oct 27, 2008 05:38 PM
They have this at MSA..
http://www.thezstore.com/page/TZS/PROD/IA42/50-1290
Kinda cool.
My thing is this. With a mint condition numbers matching Z, it's just not going to be a big investment. But, if you want it like that for the style, or for taste, then more power to you. This is probably the only car made in the 70's or earlier that I wouldn't feel bad for molesting it. haha
If it was a numbers matching 1971 Plymouth Superbird, I would not. haha
Brewski* Oct 27, 2008 06:50 PM
I have a stock 79 it did the exact same thing. Then eventually the FM went completely and now the AM too. I think it is internal ic issue.
z-hag Oct 27, 2008 07:47 PM
is stock stereo in 280s also clarion, as in the z31s??
if so, there are places that rebuild/restore whate3ver these4 radios---repairable in some places--have you sought out those shops??? i was going to do tha twith the one in the AE, but is working perfectly....goood luck....btw- i sent a pm...
ZBRICK Jan 4, 2009 05:02 PM
This situation is bazzar. I have not been able to figure out the problem with the radio. as mentioned above, FM is intermittent, AM works all the time.
Now that it is cold outside, i'm sure you can imagine the heater could come in handy, but it works intermittently. The bazzar part is that when the FM does not work neither does the heater and when the he FM is working so does the heater and visa vera. WTF, WTF again
Does anyone have a clue regarding this issue and what to do to fix it?
NismoPick Jan 4, 2009 07:56 PM
When you say "the heater isn't working" do you mean the blower, or that there is no heat coming out when the air is blowing out of the vents?
ZBRICK Jan 6, 2009 05:14 PM
The blower is not working.
skittle Jan 6, 2009 06:36 PM
then its time to prob pay her.. lol j/k could not help myself on that one.
ZBRICK Jan 6, 2009 06:49 PM
LOL, I guess my z finally had a problem that you all can't figure out. Score one for my z. She still isn't blowing or signing FM though. :022: I didn't know you guys could sleep knowing there is a problem out there that you don't have an answer to?:017: :103:
280zx2by2 Jan 6, 2009 07:17 PM
electronics are tricky!!!!
btw do you have a local J-yard with a zx? i have 3 in mine and 2 of them have(i assume) working radios...
good luck :023:
zfreak1981 Jan 25, 2009 11:52 AM
radio
im needing the factory radeo for a 83 280zx if anyone has one for sale
Bleach Jan 26, 2009 10:12 AM
I have one available. I'll test it first.
zfreak1981 Jan 27, 2009 03:05 PM
radio
cool, thanks bro. let me know how much
zfreak1981 Jan 28, 2009 04:56 PM
radio
any luck on the radio?
Bleach Jan 28, 2009 07:55 PM
I just tested it. No power at all, sorry.
Radio and tape don't respond.
zfreak1981 Jan 29, 2009 09:19 AM
radio
its cool man. thanks for trying
zfreak1981 Jan 31, 2009 08:10 AM
does anyone have the triple gauge cluster for the oil pressure,voltage meter and the clock setup? i would like to buy it from you if it works. i cracked the board on the back of mine:022: iv looked on ebay and tried to get in touch with zbarn and tried local junk yards but no luck.
Z Car Barbie Feb 2, 2009 11:36 PM
Try this website, ZFreak: http://car-part.com :)
