280ZX ECU help
Old Oct 19, 2008 | 07:06 PM
theplasticdr's Avatar
280ZX ECU help
Does anyone have a extra working ECM for a 1983 280 ZX non turbo 5 speed? how much ?
Old Oct 19, 2008 | 07:14 PM
i got one for an 82 non turbo 5speed... should be the same. sell it for 25 bucks plus shipping?
sound fair? your call. any one that wants to verify they are the same do so. im not sure but im fairly confident in that statement....
Old Oct 20, 2008 | 02:15 AM
i was told that only a 83 will work in a 83. anyone know something i don't.
if it will work snwbrderphat540 i am on it.
Old Oct 20, 2008 | 09:29 AM
sounds fair enough to me. i took it out of my NA ZX that raan perfect (only thing good about it) and its sat in my closet since...
Old Oct 28, 2008 | 07:33 PM
got a new ecm installed.the car still runs bad. the brake, door, and fuel light are on. i did a search and checked the alternator it's good.all the connections are tight. can't keep it running to check the voltage. it has new plugs wires and fuel filter. any ideas? please help.
Old Oct 28, 2008 | 07:40 PM
KasbeKZ's Avatar
Pr0n Addict
i would guess that either all your connections are not good, and you should check again, or that the lights and the poor running are unrelated. i don't think that the lights and the poor running are related.
to fix the poor running, do the regular tune up, like dizzy cap and rotor, check all the plug connections, do a balance test to see if it's one specific cylinder, make sure it's got fresh fuel in it, then get back on here.
Old Oct 28, 2008 | 08:23 PM
How did you check the alternator if you couldn't check the voltage? If all the dash lights are on, the alt is likely not charging, or over charging.
Bad running could be timing, AFM, TPS, CHTS, clogged fuel injectors, low fuel pressure...
Old Oct 29, 2008 | 12:54 PM
it has a new cap, rotor, and plugs it's my daily driver so fresh gas.i checked the firing order, it's good. when you say a balance test, do you mean a compression test? i can do that.
NismoPick i checked all the connections on the alternator they were tight. took it off and had it checked at the local auto parts store.they said it was good??? can't check the timing till i can get it started. right??
i think it may be low fuel pressure. i will try to find a pressure tester.
what is the AFM, and CHTS
Thanks for all your help, i miss my Z
Old Oct 29, 2008 | 01:15 PM
KasbeKZ's Avatar
Pr0n Addict
AFM: air flow meter. near the intake, wires going to it.
you can static test the timing, which can give you a general idea, but not accuracy.
by balance test i mean pull plug wires individually to see which one doesn't make a difference in the way it runs. pulling a plug while it's running like you say it is should just stop the engine. if you pull one and it keeps going the same, there is something wrong with that cylinder. you need to check that that specific cylinder is getting spark then, then you need to see if it's getting fuel (is the plug wet).
Old Oct 29, 2008 | 01:24 PM
AFM - Air Flow Meter
CHTS - Cylinder Head Temp Sensor
Old Oct 29, 2008 | 03:43 PM
is there a way i can test the AFM and CHTS while the car is not running??
Old Oct 29, 2008 | 04:06 PM
KasbeKZ's Avatar
Pr0n Addict
yeah look it up in the FSM. it deals with testing resistances.
Old Oct 29, 2008 | 04:43 PM
#1... Are you sure you got the correct ECU?
#2... Does it run (idle / rev) at all? You said it runs bad, but won't stay running....
#3... Pull all spark plugs & look @ the tips... Are they wet? Dry? What color?
Old Oct 29, 2008 | 05:07 PM
NismoPick #1 yes
#2 no it will not run. it starts then stalls
#3 the plugs are new. when it started running bad i replaced the plugs cap and rotor.
the car has been my daily driver. i noticed the dash lights. did a search, checked the alternator.that's when i noticed the ecm smelled burnt, opened it up and found it fried. i got a new one (for a 83 only) installed it, did a complete tuneup. now i cant get it to start.
Old Oct 29, 2008 | 05:13 PM
KasbeKZ's Avatar
Pr0n Addict
if it starts for a second and runs decently, then stalls out, it's almost definitely fuel delivery. i'd put the fuel pressure test at the top of the list now.
Old Oct 29, 2008 | 06:04 PM
fuel pressure test will be done tomorrow when i get in from work.
thanks guys
Old Nov 13, 2008 | 03:11 PM
Fixed
Old Nov 13, 2008 | 03:13 PM
Maybe you could elaborate more than "fixed" ?
Old Nov 13, 2008 | 06:20 PM
New alternator (voltage too low, amps too high) cleaned all the engine grounds and the dash grounds. Another ECM, also did the little trick on AFM. Runs better than it ever did. Thanks Nismopick you were right about the alternator.
The first time I had it tested off the car at Auto Zone and they said it was fine, got it running and drove it to O'Reillys and they tested it and said it was putting out 12.2 volts and 167 amps. Maybe that's why I fried 2 computers.
Old Nov 13, 2008 | 06:36 PM
lol at the amps! yeah seems those out of car testers SUCK and autozone alternators SUCK. i was helping jeff from the forums out and i couldnt find a short anywhere in the car told him to return the alternator and get one from a different store and i havent heard a problem from him yet.
Old Nov 14, 2008 | 12:32 PM
snwbrderphat540 is that a ZX 10.
I got my first Kawasaki in 74 the H1 500. traded it two years ago for my 83 280 ZX.i have always had a Kawasaki. now i have a 92 Concours. when i find a crashed Concours 14 that will be my next bike.
Old Nov 14, 2008 | 06:42 PM
its a zx6r an 06 the 636 baddest middleweight out there
even though the ZX10 is a beast probably the best of the motors out of the liter bikes i wouldnt own one they didnt hit enough good points in asthetics or handling if i keep this bike ill ride it till about 2012 maybe depends if i get bored or not then get the R1 of this year haha. unless im rich enough to get a new bike by then.
