250 is possible
Old Nov 27, 2003 | 07:07 PM
Skully's Avatar
wow without boring??....that would be cool to see....
Old Nov 28, 2003 | 06:08 PM
Lazerus's Avatar
Is that with a stock turbo? If not, what are they running?
Old Nov 29, 2003 | 08:59 AM
Skully's Avatar
yeah lol....i mean 250 with those mods....i wouldnt mind looking into it....
already got flat tops and bigger TB and 2.5" exhaust and making an intake....
Old Nov 29, 2003 | 11:35 PM
I'd guess super high compression of maybe 12.5:1 or higher, a long duration cam that offers no torque and is not considered streetable, and a balanced and blueprinted block so they can run up near 8,000 rpm.
Old Nov 30, 2003 | 09:36 AM
Skully's Avatar
damn you
and bleach shatters my dreams again...thank you very much mr.bleach
Old Dec 1, 2003 | 09:44 AM
Yes, but that setup you mention above is not going to pull 250 crank hp... I really don't think so. Plus if you want over 200hp you'd better not be running and open chambered head with high compression. Even with octain booster, that's not the best design for power at high rpms.
For torque and high end power fairly cheap and streetable, there's still no replacement for displacement. (or a turbo!)
But that's not to say you cant build a pretty fast n/a 2.8L
Now Norm, the guy with the 12.9 sec dual SU 240Z. He has a light weight car, smaller diamter tires and a 3.9 rear. (about 4.11 overall ratio) He runs about 11:1 compression. He raised his compression even higher to about 13:1 and dropped a few thenths off.... then blew something up! He does run an open chambered head that's shaved so far its practically taken on the closed chambered design. (hard to explain)
I'd think for a 250hp 2.8L you'd have to start with a closed chambered P90, shave that thing way down or get custom domed pistons to raise the compression way up. You'll need ported intake/exhaust and the aftermarket ECU would help. The cam will have to be large enough to flow that air and fuel in at high rpms.
I did read and have a picture of a professional road race L28 that was built for max hp and a good torque curve as it is used in professional racing. I don't know many specs on the build, but they claimed approx 270hp and 260 torque from it with a nice midrange. (what exactly that means I don't know) You can see it uses a single throttle body on a log style intake manifold with aftermarket fuel injection. Sump oil pan for holding high rpms for long periods of time. I don't know what the redline on this is. Maybe up near 9 or ten grand...?
You can also see it uses an aftermarket distributor to keep that timing dead on at the high rpms. The stock Nissan unit is just fine for most applications to 6,000 or so as long as its in good shape. They do get sloppy after all these years.
Old Dec 1, 2003 | 09:58 AM
LoopMaster, I'm not trying to put everything down that people say! Its just that most engines produce less power on a dyno than the owners claim originally. I was in the same boat with my mild buildup of my car.
stock P79/F54 block. (8.8:1 compression) stock cam, intake manifold, ECU ect.
K&N cone filter, smooth induction tube, larger throttle body, headers, 2.5 inch exhaust.
Stock tire size and stock 3.9 rear
I pulled about 145 rear wheel hp and that's basically what the factory says a new engine does when new!
The guy right before me had a 240Z with a 2.8L, mild cam, tripple webers, EI, headers, 2.5 exhaust. He pulled a whopping 200hp! NOT, actually he got 151hp. Most people with tripples claim they've got a 200hp engine.
And then there's the 510 guys who build a pretty fast L20b and think they've got 170hp or so... on the dyno it ends up being about 120-135 hp. :-( Even the new 350Z with 3.5L engine and DOHC and all that new technology actually pulls 240 rear wheel hp.... and we're trying to reach that with less displacement and only 2 valves per cylinder. I'm just saying it hard to do!
If you have more info on any specific L28 build ups that would be great. And maybe a dyno on that engine so we know just what is acchievable with those specs.
Old Dec 8, 2003 | 02:03 PM
I've not raced many Z-cars... only one 280zx and I think I was faster... it was on the highway but I have no idea what he had done to his car. Obviously it was not a turbo or I would of been left in the dust!
My 145hp 280ZX does a bit better than other Z's i think on the top rpms due to the intake/ exhaust work. Its really not that much. I had another 280ZX (my wife's) that was all stock except for a 4.11 rear. Same transmission as mine and everything. Her car was very fun. Lots of torque due to the gearing and the small exhaust but that thing felt out of breath above 4,000 rpm. After I caught up, i blew past her car. My car needs work though. its not in the best shape anymore. I'm probably not at 145hp now with my sloppy timing chain
