ZDriver.com
-   280ZX Brakes, Wheels, Suspension and Chassis (https://www.zdriver.com/forums/280zx-brakes-wheels-suspension-chassis-81/)
-   -   Taking out the rear subframe, where dem bolts? (https://www.zdriver.com/forums/280zx-brakes-wheels-suspension-chassis-81/taking-out-rear-subframe-where-dem-bolts-35076/)
WanganDevilZ May 6, 2012 01:19 PM
I have located six (Two for each of the mounts for the subframe, and then the big bolt itself that goes through the bushing) of the bolts that I know I need to undo, and then the six bolts that attach the struts to the towers, but what all other bolts are there so I can drop it out easy tonight
http://i213.photobucket.com/albums/c...tral/RSFrm.jpg
NismoPick May 6, 2012 01:23 PM
You've got the major shtuffs. I would just leave the ebrake cable in place & detach it at the U coupler. Then just disconnect the brake lines from the calipers. Don't forget the drive line coupler bolts if the diff is coming out too. I believe you will also need to disconnect the left cv axle to clear the exhaust.
WanganDevilZ May 6, 2012 06:22 PM
The reason I'm dropping the rear sub frame is because I'm under the assumption that I need the turbo rear end to go with the turbo motor/T5
Why not take everything, and swap it over all at once?
Correct?
I'm prepping for a new Z in the garage
NismoPick May 6, 2012 08:33 PM
Want or need?
You don't need the "turbo rear end". FYI, the turbo R200 is a 3.54 which is lower / slower gearing than the 3.9. :D The only benefit to the turbo rear end is the cv axles instead of half shafts.
I'm still running my 81 n/a rear end with half shafts and a CLSD 3.7 R200. I do have an 82 turbo rear end that I will throw in if I ever mangle my 81 (I'll do the camber cuts like PurePontiacKid), but since I'm still using the stock sub bushings, I doubt that will ever happen.
WanganDevilZ May 6, 2012 08:47 PM
Originally Posted by NismoPick (Post 310360)
Want or need?
So I'll be good with the N/A diff? I'll just need the Turbo driveshaft, aight?
How do you get the bolts off on the driveshaft, I've heard they're srs torqued on there
NismoPick May 6, 2012 08:53 PM
Yup... no strength difference at all between the two diffs.
A combo wrench and someone sitting in the cockpit to put in in gear / out of gear so you can spin the shaft 4 times. That's all it takes. :D
WanganDevilZ May 6, 2012 09:00 PM
Currently, the trans and engine are out of the car, and the rear wheels are on ramps. =(
I'll figure it out
FricFrac May 7, 2012 03:27 PM
I think the CV setup is worth swaping in... I believe you can take the guts out of the 3.9 and swap it into the 3.54 or swap the output flanges into the 3.54?
WanganDevilZ May 7, 2012 08:17 PM
I'll definitely be keeping everything except the chassis, nothing will be wasted
WanganDevilZ May 12, 2012 03:53 PM
don't let any body part be under the subframe when you finally undo the last bolt
safety first
NismoPick May 12, 2012 05:40 PM
Oh, BTW... as one piece it's heavy as hell, so don't let it fall on you. :D
