I found out about brake upgrade
Old Jun 17, 2003 | 11:35 AM
How about someone makes a pattern to cut a steel plate that will bolt onto the ZX front strut and hold the Toyota 4x4 caliper? That seems to be the cheapest method of a brake upgrade. Even buying brand spaking new calipers from a Toyota dealer would be cheaper than the brake upgrade above!
And the vented rotors on the ZX should be large enough for almost any application. If you still can't stop, get better tires!
Old Jul 3, 2003 | 11:36 AM
Interesting. I'm mainly concerned with street use, and more response with less pedal movement is what the larger pad gives you. That's not always needed on a road course.
What brands or "types" of brake pads do you suggest then for the stock 280zx brakes? I'd be interested in trying some the next time I change brake pads.
Old Aug 1, 2003 | 08:38 AM
So it was suggested not to use metalic based brake pads. What then is the recommended type? I've seen metalic and organic as the most common. Do the metal ones last longer but give less grip? So should I use organic pads and just have to change them out a little more often? That's definatly what I'm willing to do. I do my own brake work so its really no problem at all.
Old Apr 28, 2004 | 07:29 PM
smartman3000's Avatar
Okay, just take a step back and read what you just wrote. That'll get you killed, and kill someone else. Don't be an diot. If you can't spend that money, don't drive the car until you can. Don't do it. What you wrote is just stupid and any half wit wouldn't even think about it. Use your head.
Brian
Old Apr 28, 2004 | 09:15 PM
Skully's Avatar
[QUOTE=mikado]Apparently there are now ceramic brake pads. What about these? Does anyone have any info?
well ceramic brakes dispurse heat easily and break well under high temp conditions and after you stop they recover easy
you also dont get much brake dust with ceramic brakes and braking is quieter
Old Apr 29, 2004 | 08:50 AM
CrazyBrakes99:
The cheap way to get the brakes fixed is to just buy one caliper used. Either from eBay, someone online, or a junk yard. (I now hate yards as they charge way too much) Then buy a rebuild kit that covers both rear calipers. You can re-use your other cailper as its just as good as a used one.
That should fix your problem. I'm actually on my third rear right caliper. Not rebuilt three times, I've had to replace the caliper twice and rebuild it with new seals. There's something wrong with these things... Its always something with the parking brake lever, and it can actually destroy the cailper. But now the parking brake cable is stuck.
jtz31ae
May 30, 2008 03:54 PM
CodeWarrior
Sep 15, 2005 06:09 AM
tt300z
Jan 8, 2005 06:11 PM
sk8ur_9
Dec 20, 2004 08:03 AM
1tuffz
May 8, 2003 12:42 PM
