Brake Problems, hose leaking at caliper threads
Old Sep 9, 2012 | 04:36 PM
WanganDevilZ's Avatar
The Emblem Thief y0!
I recently installed brand new brake pads, rotors, calipers, and brake hoses.
Now, kind of a big issue, brake fluid is leaking out of where the caliper and the brake hose connect, I never received a brass crush washer with the hoses, do I need to go get a few?
The fluid seeps out from pretty much all 6 sides of the end of the hose, and only when you step on the brake, and it comes out one droplet at a time, it doesn't stream out
Right hurr: IMAG0036.jpg?t=1347233503
also, is this the master vac needing to be replaced?
V----Click for video----V
Old Sep 11, 2012 | 07:30 AM
Mishimoto's Avatar
Did the new hose come with crush washers? They usually do and i would definitely recommend reinstalling this with some crush washers.
Old Sep 11, 2012 | 07:49 AM
I grabbed some at work, will reinstall today, I was irritated that they didn't give me any at the auto parts store, but thankfully I was able to get some for free
Old Sep 11, 2012 | 08:03 AM
Mishimoto's Avatar
Free is good! Sometimes the items get packaged incorrectly at the factory. Or someone buys the hose, takes it out and decides to return it and forgets or takes the crush washers. I've seen both of these happen.
Either way GL and let us know how it works out.
Old Sep 13, 2012 | 04:38 PM
Still haven't gotten around to putting the crush washers on the brake lines yet, has either been a little warm, raining, or I get off too late to do it or I don't have anyone to help me bleed
But to the video I posted, Brake Master Vac?
Old Sep 14, 2012 | 04:46 PM
That's what you're clutch/brake does before/while you're bleeding it. Bleed it first...
Old Sep 17, 2012 | 06:33 AM
Mishimoto's Avatar
+1 install the washer, then try to bleed the system. Let us know how it goes!
Daniel Coffman
Apr 14, 2013 08:26 PM
float_6969
FS: 300ZX (84-89)
Sep 23, 2012 05:58 PM
Pearl White Z32
Aug 7, 2012 07:53 PM
JCastro2866
Jun 21, 2012 05:53 AM
zfanman
Oct 30, 2008 11:36 PM
