Uphostery - first attempt at recovering a car seat.
Old 01-05-2019, 02:19 AM
Thought this might be a helpful reference for anyone wanting to redo their seats. This is my first attempt at a car seat so I did a lot of reading and watching YouTube videos. I've got a little bit of experience fixing up a couple of antique chairs so I thought I'd try my hand at some automotive upholstery. I bought an industrial sewing machine so I'm kind of committed now The plan is to do the interior on the 4dr 510 but thought I'd practice on my daughter's 240SX interior. The seats are BEAT! I can only make them better than what they are and that's not saying much - a piece of duct tape is a vast improvement
On the "to do" upholstery list
The 4dr 510 and future upholstery recipient
So lets start with some before pictures. Like I said I can only improve on this
FricFrac is offline
Old 01-05-2019, 02:20 AM
I won't put all the pictures I took here but I'll try and keep it as step by step as possible so you can see the process. Take lots of pictures as you take it apart. Sometimes there is something you need to go back as reference. In this picture you can see where the top stitch was done so that you replicate it when you sew it back together and it lays properly.
Bottom of the seat - you can see where the hog rings attach the seat cover and hold it in place.
On furniture you use staples into the frame to hold the fabric in place. On a car seat you use hog rings and wire in a pocket sewn into the cover.
or a reinforcement of some sort like these plastic sew on strips
I'm reusing the wires from whats left of the seat covers so I make sure they are labeled. You can make your own of course. It looks like they bend the ends back to keep it from poking through.
FricFrac is offline
Old 01-05-2019, 02:22 AM
Now the fun part - time to get creative. My daughter wants to paint the car powder blue so the theme is mainly black with pink and blue for the interior.
A blank slate. Vinyl on top glued to 1/2" foam then a bottom layer of fabric glued to the other side of the foam to make a vinyl/foam/fabric sandwich. Layout is done in chalk - it doesn't stain and is easily erasable. Just sharpen a stick of chalk on a piece of sandpaper to get a chisel edge to do fine lines.
I haven't seen this anywhere but I thought I'd try it. Using a bamboo basket weave pattern embossed vinyl and glued diamonds onto the panel with contact cement. You need to be very precise with the cutting so a ruler and Olfa blade works very well.
Before gluing down textured vinyl on base
Panel sewn. You can see how the 1/2 foam sandwich makes nice pleats in the panel.
Close up of the diamonds
FricFrac is offline
So I start watching some YouTube videos so I can try and figure out how to do this and of course I decide to go with a blind stitch because it looks cool. Problem is that it works for one row of diamonds but the material starts to bunch up if you add another set top and bottom.
Layout for blind stitch
Too much puckering :/
But a chance to see what the upper panel will look like on the seat
Do over on the panel. Colour is just washed out with the camera and lighting. There is a problem with the stitch on the bottom RHS diamond which I have since fixed. Added a second row of top stitching.
FricFrac is offline
Old 01-05-2019, 02:23 AM
Now that I've got the main panel for the back of the seat done I'm going to do the seat. These are the two main panels and the majority of the work. My daughter and I decided on textured stripes to match the diamonds on the seat back. The angles are the same as the diamonds and the pleats will match up to the seat back.
Test layout
Precision fitment is critical here. Not sure if this is the way to do it but it looks sharp in the end.
Kind of wrinkly from manhandling around the sewing machine.
Some close ups to see the stitch work.
Colour is washed out but more detailed shots.
Rough idea of the main panels.
FricFrac is offline
Old 01-06-2019, 11:46 PM
Progress on back panel
FricFrac is offline
Old 01-10-2019, 11:46 PM
Test layout for grommets.
Installed
Test fit - hog rings not installed yet
Grommets with inserts
Cleaning the glue gun can be a pain. Work smarter - not harder!
Seat bottom panels starting to go together
FricFrac is offline
Old 02-28-2019, 04:19 PM
locknar's Avatar
looking amazing! awesome work
locknar is offline
Old 06-11-2019, 05:26 PM
Austin Jones's Avatar
Wow
Great job. Very creative
Austin Jones is offline
datsunbat
43
12-23-2019 12:13 PM
Niku-Sama
25
12-08-2008 09:55 PM
iluvJDM
01-13-2008 11:50 AM
91Zman
FS: 300ZX (90-96)
08-20-2006 09:58 PM
chinesekid
08-17-2006 01:05 PM
Quick Reply: Uphostery - first attempt at recovering a car seat.
