Seat question
Old Nov 12, 2010 | 01:20 PM
garretthes's Avatar
Seat question
Are the seats from an 82 2+2 the same as a 79 coup?
Old Nov 12, 2010 | 03:55 PM
BlueKitsune's Avatar
Intrawebz Wizard
Yes. other they maybe ones being high backed. and the others being low backed. Other then that they drop right in. might need to bolt your old seatbelt buckle onto the new ones but they should fit fine too.
Old Nov 13, 2010 | 09:25 AM
garretthes's Avatar
Is there an after market option for 280zx seat foam? I have searched for weeks but no luck.
Old Nov 13, 2010 | 05:28 PM
Daemione's Avatar
I'm in the same boat, but haven't found anything other than $$$ custom. I've pretty much given up restoring my stock seats, so I'm looking at inexpensive aftermarket options now.
Old Nov 13, 2010 | 05:34 PM
https://www.zdriver.com/forums/showt...&highlight=crx
Old Nov 13, 2010 | 09:14 PM
garretthes's Avatar
Thanks for the thread Nismo, we already have new OEM covers for the factory seats so we are locked in with stock. I'm heading out to look at some seats at a salvage yard Monday. If they are in decent shape I will get them and use the foam and frames to save some time. No matter what it looks like I will have to fab the back out of high density foam from here:
http://www.rochfordsupply.com/shop/Foam/index.html
Old Jan 2, 2011 | 01:21 PM
dammitmitchell's Avatar
hey yall,
Here's how we do the foam in aviation. You can find the foam in block form and use a hot wire cutter (easiest way) to repriduce the foam curves for the seats.
http://www.instructables.com/id/Hot-wire-foam-cutter/
Also this is a trick ive done on my chevys, you can add an additionaly 1/4 or 1/2 in layer of rolled foam for additional comfort .
attacksoma
Mar 10, 2010 09:44 PM
SoCal-s130
26
Sep 13, 2006 10:36 AM
AFSteve
Sep 3, 2006 08:59 PM
Team7
Apr 10, 2006 05:51 PM
halfbaked5041
Sep 22, 2002 04:40 AM
