S 130 Air Dam, Bumper cover
Old Dec 7, 2014 | 06:54 PM
mikey280zx's Avatar
Well this is about my approach to the weak chin of the S130 I own. Looking for months and evaluting the situation I found that all the commercial options wopuld still need to be worked to get rid of gaps. Quite a bit and I still was not sold on what I would have. One outstanding example of a builder is the red and white striped 280zx. I included it as "thought" for others as it was for me. The silver car show gaps in whats available and what it looks like if not fared in proper. So I took what I liked and left what I didn't and started to make what I wanted.
I removed the cover and steel reinforcement, planning to incorporate some sort of steel collision protection with new look. I used 1" building insulation and cut pieces using bumper reinforcement as template. I stacked enough to fill the area where old bumper fit. I moved this in from original position to what looked good to me. I glassed these and made a lower lip out of one thickness same foam, glassed both sides.
I supported these in place and started using can foam to fill in areas to be flush with front face of bumper. I used 2" thick foam blocks in center area and looked at different configurations to choose what I think looks and will work best for grill.
Attached Thumbnails S 130 Air Dam, Bumper cover-profile_007.jpg   S 130 Air Dam, Bumper cover-profile_009.jpg   S 130 Air Dam, Bumper cover-profile_008.jpg   S 130 Air Dam, Bumper cover-wonderful-custom-front-end-79-280zx.jpg   S 130 Air Dam, Bumper cover-front-right.jpg
Old Dec 7, 2014 | 10:09 PM
zxguy1986's Avatar
Nice work so far, mikey. Please keep us up to date with your posts as you continue with it. End result can be amazing! Thanks.
Old Dec 16, 2014 | 07:59 PM
mikey280zx's Avatar
Progress being made. working vertical surfaces now then I need to cut horizontal lines. Happy so far. I am making a wood and glass center insert to replace hokey foam pieces grill area. Off for a month to Calif. I will be back.
Attached Thumbnails S 130 Air Dam, Bumper cover-dscn1438%5B1%5D.jpg   S 130 Air Dam, Bumper cover-dscn1444%5B1%5D.jpg   S 130 Air Dam, Bumper cover-dscn1439%5B1%5D.jpg
KyleTheKid
Apr 20, 2015 06:33 AM
Niku-Sama
Sep 13, 2008 09:33 PM
skittle
Feb 9, 2007 08:15 PM
94300zx
Aug 8, 2002 09:55 PM
