right side door is ****'d
Old Jan 18, 2005 | 09:40 PM
B1nAryVilE's Avatar
My right side door is not opening what so ever it doesn't open from inside or out and the lock doesn't work as well someone tried to break into my car and now the door is crap tacular i've tried everything to take off the door is there an other way of removing the whole door or just fixing it. any help would be great.
-chuck
Old Jan 19, 2005 | 06:10 AM
DoTheDrew888's Avatar
Pop all of the rivets on the inner door panel and lift it up and off the door. Under there is a plastic sheet that you can just peel off. Once you get that off you should be able to look inside the door and see whats wrong.
Old Jan 19, 2005 | 10:08 PM
B1nAryVilE's Avatar
you can't remove the panel from the inside well i haven't found a way they are wall to close to the inside panels from the dash board.
Old Jan 20, 2005 | 07:49 AM
BJ BISIG's Avatar
My $.02
-chuck
i'll bet they knocked the latch rods off. try rolling the window down, use a wide blade screw driver to spread the window opening and look in with a flash light. you should be able to hook the door latch mech on the inside of the door to pop the latch.
if all else fails, take it to a good body shop. they should be able to help.
good luck, bj
Old Jan 20, 2005 | 12:44 PM
Get one of the door unlocker things that cops use. Maybe it is locked and the mechanism broke.
Old Jan 20, 2005 | 07:42 PM
B1nAryVilE's Avatar
I already tried a "slim jim" no go on that.......
-chuck
Old Jan 20, 2005 | 10:05 PM
81 Black L28E's Avatar
ok this sounds stupied but spray WD-40 in the lock and try using the key to unlock the door i had to do it when my lock stuck. i dont know if that will work for you but try anyway :headspin:
Old Jan 21, 2005 | 10:28 PM
B1nAryVilE's Avatar
lol the key won't even turn the locking mechanism all the way
-chuck
Old Jan 22, 2005 | 12:24 PM
If you really need to get that door open then why don't you just cut the door panel open. Im sure you could find another door panel off a junker car.
Old Jan 23, 2005 | 09:42 PM
B1nAryVilE's Avatar
OK well i got it to open i ordered the part turns out the whole mechanism where the hook clings on to the body is ****ed so right now i got it rigged with a aliminum wire solded to the hook attatched to the inside door handle just for now nothing temporary
-chuck
DeathByNissan55
Dec 13, 2020 03:42 AM
brim
Sep 16, 2013 12:21 AM
TeknikL
FS: 300ZX (90-96)
Dec 7, 2012 03:10 PM
duowing
May 3, 2006 04:29 PM
kewlcat
Oct 26, 2001 09:36 AM
