My Shifter Mod, N/A Trans
Well I wanted a short shifter for my Z. but could not go T-5. So i got my hands on a few S30 shifters, and cut/grinded one down. So here it is. I am thinking of going down a lil more.
http://i48.photobucket.com/albums/f2...3t/p_00037.jpg http://i48.photobucket.com/albums/f2...3t/p_00027.jpg http://i48.photobucket.com/albums/f2...3t/p_00028.jpg http://i48.photobucket.com/albums/f2...3t/p_00029.jpg http://i48.photobucket.com/albums/f2...3t/p_00030.jpg http://i48.photobucket.com/albums/f2...3t/p_00033.jpg |
You have a BOV for a shifter! :D
http://members.shaw.ca/wyntonm/pic/S...%20BOV%203.jpg http://members.shaw.ca/wyntonm/pic/Type%20H%20Bov.jpg |
That is a 6$ Simulated Pistion Shift Nob! and i had to replace my old shift nob. i kinda forgot to take shifter out on engine pull. i was tired. and it was late. So. after ripping out the insulator boot( Now everything is loud :( ) the red acordin boot. and my 30$ shift nob. i had to replace it. and decided to shortin it a bit while i was at it
How much did you actually cut out of it? When I did that to my shifter I took out an 1 1/2" and I like where it is right now. Any lower wouldn't feel right in my opinion.
2 1/2 inches. I love my shifters really low.
I wouldnt take any more off. You didnt even have to take any material off. you just Dog leg it like I was saying in your other post. Heat it about an inch above the hole, put it in a vice and bend it back. Cool it. Heat another inch and a 1/2 above your first bend and push it forward. Short throw, specially' with all the material you already removed, that thing would be SCCA ready. I'll pull my shifter out this weekend and put it next to a stock unit and show you guys what I'm talking about. Nobodys heard of doing a short throw like this?? This cat I used to work for auto crossed Z cars in the late 70's and said he did it all the time. It works.
Are you saying to make it look like this?
http://i6.ebayimg.com/06/i/001/37/76/3524_1.JPG That's not making the throw any shorter, just moving the position. The "technical" way to make a shorter throw is to lengthen the bottom pivot (like a lever in physics). |
(Post 252663)
Originally Posted by straight hate
(Post 252668)
and flipped the plastic piece(82') upside down, lengthing the bottom pivot. Does that count? Or is it just a mind fuct, it feels shorter.
So, for anyone doing a search, this might be of some use. After you dog leg the shifter you must flip that platic piece around to lengthen that bottom pivot point... Creating a short throw shifter. Then shorten it to desired length. Do I have that right Nismo?
