Hazard Switch Delima
<a href="http://s286.photobucket.com/albums/ll89/280zx2by2/?action=view¤t=DSCN0245.jpg" target="_blank"><img src="http://i286.photobucket.com/albums/ll89/280zx2by2/DSCN0245.jpg" border="0" alt="Photobucket"></a>
got a hazard light switch from a 79 that has 5 green wires, problem is my 81 has 4 green wires, a blue and a red... 79 wire colors -solid green -green w/ white stripe -green w/black stripe -green w/yellow stripe -green w/ red stripe 81 wire colors -red w/ white stripe -solid blue -2 solid green wires -green w/red stripe -green w/ yellow stripe i need the harness from the 79 (as mine was missing) is this still plug and play or what? :102: BTW HAPPY NEW YEARS EVE!!!!!!!!!! :038: |
Is the plug different as well?
no i think the plug is the same just dif wires going into it, dont know if i should try to just plug it in as there might be an explosion, or just some smoke...
i just went through my FSM wireing diagram, the cooling fan is connected to the hazard light switch, why?
it does explain why when i removed an alarm system that was connected to my hazards my fan quit working |
The cooling fan? As in the injector / manifold fan?
Maybe Nissan thought it would be bad to have the fan come on if you are stranded... :D |
Maybe Nissan thought it would be bad to have the fan come on if you are stranded... :D well i went out and pluged it in, it works, but only when the power is on, the odd wire out is a red w/ white stripe (power wire mabe?) do 79 hazards work w/o the power on? |
CAN SOME ONE GO OUT...
to their 280zx and turn on the hazard lights w/o the key in when you come back can you answer me this riddle, when you turn on you hazard light switch, does the car turn on? exaple: fuel pump turns on, and you can use power windows... like if you turned the key past acc. into the ON position... i have checking both of my parents fords and the only thing that comes on when the hazard light switch is on, is the blinkers.... |
I would... but I'm at work... and my Z is buried in the back of my garage somewhere....
the fuel pump and stuff don't come on with the hazards :)
Why post a new thread? Just hijack someone else's 10th anniversary thread with your question.
thank you SpeciallySpiked, i got tired of bleach not doing a simple task for me, so i realized that it wouldnt be safe for them to have the fuel pump running while your cars sitting on the side of the road so i got to looking and found a hole bunch of connectors linking all kinds of crap, disconnected them pluged in my switch and every thing worked
thank you again... |
Doing a simple task? I was at work. You are 3 hours ahead of us. I just got home, fooz!
Right on. You and those gaters have a happy new years too
