anyone have this??
anyone have this??
taillight "update"
I've been tossing around the idea of buying this thing... anyone else put it on? What about relocating the licence plate?
Originally Posted by WildmaN
I no likey it either. It just doesn't look right! And that auction has been on there for quite a while!
Originally Posted by Heat Rave R
I yoinked one of those panels off a car in a junkyard. I figured I could hang it up on my garage wall or something for decoration. ^^
Personally, I don't like the look at all, maybe if the lettering wasn't so big.
P.S. has anyone seen smoke taillight covers for these cars, I am painting my car black and I want the taillights match somewhat!
i've not seen any covers... your best bet would be to buy some of the trillogy spray paint made for spraying tail lights and other assemblies. They look pretty good... someone on here has a set painted. Can't remember who though
I've got one on mine and I like it.
These have been available since the early 80's when the ZX came out. I had one without stripes on my '80 280ZX.
Didn't have one on my '82 NA, cause I didn't want the weight.
I now have one on my '82 3.1 Turbo.
The license plate is mounted under the bumper though. Don't drill holes in your bumper with screws.
All you need is a piece of L bracket to bolt it to the underside of the bumper on the steel support. That will keep your bumper clean and un-molested.
If you look in my pic below, I've moved the front license plate under the bumper and offset to the drivers side as well so it won't block air flow to the intercooler.
It looks much better and gives it a little Euro flair.
Originally Posted by lessthanjabo
looks good lww, I don't have a front license plate so I am covered there... I plan on buying the MSA Aero Kit 2 soon... any Idea on where to put the plate then?
It looks good because it blends the bumper in with the air dam.
If you have to have a front plate, I would go with the same mounting position. I believe the Aero Kit 2 still uses the same bumper cross member as the factory bumper, but I could be wrong. If it does, you'll just have to mount your L bracket through the Aero Kit into the steel cross member and then screw your license plate into the L bracket.
Taillight covers
Thanks for the tip, i'll try it!
