VK56 swap, need info please.
Im contemplating doing a VK56 swap into my 75 280z, but i need to know first what is the most reliable, powerful, easy to work with, and readily available version of the engine and engine management system.
I plan on running my own ECU so when i say engine management system i mean engines with as little of the regulatory modules on the engines (EGRV, Fuel content analyzer for flexfuel, etc) as possible. Also, if you happen to know extensive info about crank/flywheel/trans input shaft for the nissan titan, I'm thinking about mating a T56 tremec to this so I'd like to know spline specs, dimensions, bolt arrangement, etc. Let me know asap! |
Another important thing you'll need for this: a fat wallet.
Good luck with the swap |
Not to be a "downer", but with questions like this, I don't think you're ready to take on this project... (no offense). :)
Originally Posted by DeathByNissan55
(Post 332835)
I but i need to know first what is the most reliable, powerful, easy to work with, and readily available version of the engine and engine management system.
(Post 332835)
(Post 332835)
VK56 with 350Z Trans???? - Other V8Z Tech Board - HybridZ 240z [Archive] - TexasNissans.com |
(Post 332876)
MegaSquirt. MegaSquirt. Good reads: VK56 with 350Z Trans???? - Other V8Z Tech Board - HybridZ 240z [Archive] - TexasNissans.com |
The fat wallet comment is VERY much true. I'm doing the same thing with my 78 and Ive still been tinkering away on it for a year now.
