What is this thing?
about four inches inback of my oil filter on the engine block toward the transmission is threaded stem with a bolt screwed all the way down. It sort of looks like a drain plug. Any Ideas
Thanks g. |
Re: What is this thing?
do u have a pic of it, that would help.
David 1TuffZ zccr.net https://www.zdriver.com/rides/spec/p...1016465706.jpg |
pull it out and look at it
-jeremy- |
Oil Pressure
That is where the oil pressure sender unit is supposed to go. If all you have is a screw, then your oil pressure gauge will probably read zero.
There is also a head temp sensor in that same area, futher back toward the transmission. If that is off, then your engine will run very bad! (very rich, like it is cold) http://www.zipcon.net/bleach/pages/zcar/zlogo.jpg |
