trouble replacing ball joints on a 240z
Old May 19, 2003 | 11:19 AM
auxilary's Avatar
the Dude
you might want to start by telling us what you're having problems with.
To remove the balljoint, unbolt the trailing arm (2 14mm bolts) and 2 support bolts holding the balljoing in to the control arm
unbolt 2 bolts holding the steering knuckle to the strut.
separate strut and steering knuckle
remove cotter pin from balljoint nut, unbolt nut, and use a pickle fork or a clamp to separate the balljoint from the steering knuckle.
Old May 20, 2003 | 05:34 PM
auxilary's Avatar
the Dude
little known trick if you're removing the tie rods - the driver's side tie rod is reverse threaded. you'll have to tighten it to loosen it
Male
20
Aug 23, 2012 01:45 PM
Monkies
Jan 13, 2011 06:31 PM
EZDUZIT
Aug 8, 2008 05:38 PM
007max
32
Jun 24, 2007 09:50 AM
kevtt
Apr 5, 2007 10:15 AM
