1977 280z ziva
Old 10-05-2017, 10:34 PM
Dreadnought4629's Avatar
1977 280z ziva
Hello all I recently got this 1977 280z with 76k miles. The kid that I bought it from burnt up the engine harness that he had rebuilt, he swapped the connectors for the iacv and the cold start injector and burnt the injector and the wiring all the way back to the ecu. After trying to salvage it I went to pick n pull and got a good one for $80 cleaned all the connectors and threw it in and she was alive again. Then replaced the front shocks and ball joints and head lights with led and a 95 amp alternator. Cleaned and repainted some parts and removed the bumpers.
I also have a 84 720 4x4 I'm building but that's a whole other story -_- anyways did an engine swap with megasquirt and since its still down. In pulling the ms2 out of my truck and putting it in the z. I had it in there and running but the tach was spiking so I need to get a better ignition module with a tach output and a spacer so I can fit a ka throttle body. That's about it so far but have much better plans
Dreadnought4629 is offline
Old 10-08-2017, 05:53 PM
I have a present for you...
theramz's Avatar
Welcome, I'm interested in what you did to get the MS to work.
theramz is offline
Old 10-08-2017, 06:50 PM
when I bought the car they did the HEI conversion but they got the 4 pin and it doesn't have a tach output so I need a 7 pin module
bml66
07-13-2003 07:18 AM
bml66
07-10-2003 07:14 PM
amc
07-08-2003 05:00 PM
aronjr84
11-15-2002 06:22 AM
philk
03-31-2002 10:14 AM
Quick Reply: 1977 280z ziva
